RV.Net Open Roads Forum: Hot Water heater shuts off after 30 seconds - Atwood
 > Hot Water heater shuts off after 30 seconds - Atwood
heyobie
Maryland
Posted: 05/09/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I have an old Atwood G6A-4E (my rv is from 1988) water heater that I updated in 2017. I replaced the gas valve assembly, ECO, Stat and new ignitor back then. It worked perfectly for 2 years until i tried to fire it up after this winter.
The problem is that it lights but cuts out after running for about 20 seconds.
While I was writing this email, I was testing again. It lit, ran for a minute and went out. After a few minutes, it relight itself and went out in 5 seconds. It just relit again and went out in 30 seconds
Does anyone know what this is a symptom of? STAT?
heyobie
Maryland
Posted: 05/09/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I tested the stat and it was open and it certainly should not be when the water is ice cold. I spend more time redoing my work because of poor quality parts. The old stat worked fine for 30 years. The new one can't make it past 2 years.
SidecarFlip
SE Michigan
Posted: 05/09/19 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Flame sensor is kaput or the spacing is too wide.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
bgum
South Louisiana
Posted: 05/09/19 11:46am Link  |  Quote  |  Print  |  Notify Moderator
High temp limit thermostat possibly. It is a nickel sized puck with wires held next to the tank with some glue impregnable felt.
TBammer
Mid-Michigan
Posted: 05/09/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Spider web in mix tube?
2016 Chevy 2500 HD, 6.0 gasser, 4.10 dif
2019 Arctic Fox 25W
Reese Pro-Series WD Hitch
Old-Biscuit
Verde Valley
Posted: 05/09/19 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Spark electrode not only supplies high voltage spark to ignite the main flame BUT is also used as pathway for 'flame proving' signal
Signal is generated via flame ionization....milliamp current which circuit board MUST sense otherwise DC is dropped from gas valve so raw fuel doesn't accumulate
Spark electrode
Soot/carbon
Wrong gap
Broken wire...bad connection
Ceramic insulator cracked
T-stat OPEN????
Should not open until water temp reaches 140*F
ECO OPENS at 180*F
IS water HOT if you pop T&P Relief Valve Open????
bobndot
Posted: 05/09/19 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit, could it be the circuit board or a dirty ground connection ?
Germania
Home
Posted: 05/09/19 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
First thing I do when having these kind of problems is remove the power and remove and reconnect all spade connectors one at a time. It doesn't work all the time but its worked enough times to make it worthwhile. Corrosion is your enemy
heyobie
Maryland
Posted: 05/09/19 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Replaced tstat. All is well. It just was opening way too early. Just a bad one I guess.
Thanks fOr helping.
Old-Biscuit
Verde Valley
Posted: 05/09/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks fOr helping.
Thanks for posting update.
Hot water GOOD!
