RV.Net Open Roads Forum: Fifth-Wheels: Checking Truck For Level?
 > Checking Truck For Level?
Super_Dave
Harrisville, UT
Posted: 05/09/19 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Is it safe to assume that putting a level on the truck bed rail when loaded would indicate how level the overall truck is riding?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Lynnmor
Red Lion
Posted: 05/09/19 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
No, that doesn't consider the surface you are parked on. Best to measure and record the empty truck fender opening height at each wheel, then compare that with the loaded measurements. Of course you might want to bring the rear down more than the front.
laknox
Arizona
Posted: 05/09/19 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
With a 4' level, you could check the surface, then compare to the bed rail. [emoticon]
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
Old-Biscuit
Verde Valley
Posted: 05/09/19 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Place level on bed rail with trailer NOT connected.
Note have much 'rake' your truck has
Then do same with trailer connected
Measure front tire to fender with trailer not connected AND connected
Much difference?
Shouldn't be with dually and 3200# wet pin (16K GVWR/20%)
Super_Dave
Harrisville, UT
Posted: 05/09/19 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Goal would be to evaluate whether pin weight put truck in rear end squat below level from empty, ass high position. I don't think that involves fender well clearances unless I'm not understanding how that pertains to truck being level when loaded.
goducks10
There
Posted: 05/09/19 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
I assume that the fender wells are the same off the ground when the trucks level. I thought all MFG built them that way. What else would you use to check level? Mine's 3" higher in the rear using the fender well when empty.
Using fender measurements takes the guess work out. Don't have to be on level ground.
Slownsy
Posted: 05/09/19 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Super Dave you are correct, but as also suggested check that you are parked on a level surface.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
Super_Dave
Harrisville, UT
Posted: 05/10/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Parked on flat ground, I put an 8', 2x4 on the bed rail and a long level on the 2x4. The rake over 8' is about 2.5" when loaded.
Cummins12V98
on the road
Posted: 05/10/19 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Park on flat ground. Stand back at the side, does it LOOK level???
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
mtofell1
Oregon
Posted: 05/10/19 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah.... I'm kind of in favor of this method. I guess the question is what is trying to be achieved by having the TV perfectly level? I understand the 5th to TV and bed rail clearance but I can't see a problem with a TV being a few degrees one way or another off level. Certainly, the trustworthy eyeball test Cummins eludes to should be close enough.
