RV.Net Open Roads Forum: Fifth-Wheels: Checking Truck For Level?
 > Checking Truck For Level?
edbehnke
North America (from Michigan)
Posted: 05/11/19 04:12am Link  |  Quote  |  Print  |  Notify Moderator
relax. just do a visual...that will do it. and even if it isn't there isn't a lot you can do unless you have air bags.
eddie and sandie
3402 Montana 2013
Ford F350 2015
ETCrockett
Greenwood, IN
Posted: 05/19/19 12:25am Link  |  Quote  |  Print  |  Notify Moderator
mtofell1 wrote:
Cummins12V98 wrote:
Park on flat ground. Stand back at the side, does it LOOK level???
Yeah.... I'm kind of in favor of this method. I guess the question is what is trying to be achieved by having the TV perfectly level? I understand the 5th to TV and bed rail clearance but I can't see a problem with a TV being a few degrees one way or another off level. Certainly, the trustworthy eyeball test Cummins eludes to should be close enough.
I agree about the bed clearance and the FW towing level. However, you want to also avoid excessive squating on the TV when loaded. I have always been told that when towing from the bumper hitch that excessive squat puts a strain on the drive shaft and cause major problems. I just assume the same would be true when towing a FW.
Eric & Andrea
2016 Jayco Pinnacle 38FLSA
2009 Ford F450 DRW
Cummins12V98
on the road
Posted: 05/19/19 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Truck LOOKS level.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
