RV.Net Open Roads Forum: General RVing Issues: Proper Protocol for “Complimentary Roof Inspection”
 > Proper Protocol for “Complimentary Roof Inspection”
Page of 5
TheBar
MS
Posted: 05/12/19 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Halmfamily wrote:
But some 4" Eternabond tape and seal over all of your joints and sealant. Follow the directions and you won't have to worry about failed sealant again. I did this to both of our FW's and in five years haven't had to touch it.
X3. I covered every roof seam including the trim on all four sides and around all the vents and AC. I'll never need to caulk the roof again. But be warned this could affect your trade in value. It should increase the value but a dealer doesn't want to sell an RV where he can't sell a re-caulk job every 3 years.
Retired factory automation computer programmer
Cabin fever solution: 30' Class C
DW loves it more than I do
pmlevine
Massachusetts
Posted: 05/12/19 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
winnietrey wrote:
Dave H M wrote:
winnietrey wrote:
as an after thought, if those holes, were there before you took it to the dealer, why would they be white, when the rest of the Dicor is stained? That makes me kind of wondering, if the dealer did something, To try and sell you a roof job
Too lazy this am to go back through and study things but I was under the impression that that was the photo the stealer sent the OP. [emoticon]
If it happened, prior to taking it to the dealer, I would expect, all the Dicor to be the same color. When I zoom in, on the pic, it almost looks to me, like someone sliced the Dicor and lifted it up and peeled it back. Could have been a branch or something, but if the Dealer did it, that would be pretty cheeseball
I had the TT covered all winter with a heavy duty RV cover, after I cleaned the roof this past fall. So no trees or branches can account for the gouged holes in the sealant.
dhull
apple valley
Posted: 05/12/19 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
That look exactly like a few of the seems I found that had bubbles under them after I put the needle nose pliers to it and ripped the top off the bubble before applying more dicor over top.
OleManOleCan
Alabama
Posted: 05/18/19 11:52pm Link  |  Quote  |  Print  |  Notify Moderator
guidry wrote:
There’s no complementary, it’s just like a car dealership doing a “free 38 point inspection”; it’s a chance to find something to repair and charge you. They WILL find something and like you suspect, they’ll even make sure you have damage so they can get your money. Buy some Dicor lap sealant and do the easy job yourself-$12.00
Learn to do all your maintenance yourself and you’ll be a much happier camper!
Find another location for maintenance.
Looks like someone is setting you up to take a lot of money.
It's easy to do your own roof replace. $150 or less.
Watch a couple of YouTube videos, and see how it's done.
derh20
Vancouver-Not BC, WA-Not DC
Posted: 05/19/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
After years of going to rv service shops, one really bad outcome made me going to mobile RV repair guy. without going into detail, the service shop de-winterized my MH and made 2 potentially dangerous errors, one involving the propane tank. One of the problems is they hire these young people with limited knowledge, and training and you don't know what they are doing behind closed doors. With a mobile person, you can be there watching everything that is being done. Just my thoughts.
pmlevine
Massachusetts
Posted: 05/19/19 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a very good option to have a mobile RV tech arrive to perform maintenance instead of bring the RV into a service center. I am totally on-board with watching a reliable mobile RV tech perform maintenance, so I can learn to do things myself.
How do members find a reliable mobile RV tech ?
bob2194
Cache,Ok Gateway to the Wichita Wildlife Refuge
Posted: 05/20/19 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^This the best advice!!! I will do the same to my new TT
20 year U.S Army veteran and still serving. Vehicle inspector (ARMY)
2018 Radiance 28QB pulled by 2018 F250 STX 6.2 Gasser
Equal-i-zer Hitch
Page of 5
