RV.Net Open Roads Forum: Beginning RVing: Weight/tow capacity question....
 > Weight/tow capacity question....
Big_steve
SW Florida
Posted: 05/10/19 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
This seems to answer itself, yet I'd like to know if I'm right or wrong. A trailer ad says:
Base weight: 3936 lbs
Carry capacity 1864 lbs
So I assume that means my tow vehicle must be able to pull 5800 lbs (both values added together)
Mojave, Kern County, California
Posted: 05/10/19 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
My daughter’s Volt can “pull” my TT but the Volt can’t carry the weight of the trailer tongue, weight distribution hitch, stuff, passengers etc. Think payload as well as max trailer weight.
* This post was edited 05/10/19 07:24pm by Lwiddis *
Dave5143
Arizona
Posted: 05/10/19 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Yes but don't be misled. That what the marketing material may say but the real live trailer may have a different weight depending on what options are installed.
Dave & Mary
2012 Denali 289RK
Ford F250 Lariat Powerstroke 6.7L Diesel
dockmasterdave
florida
Posted: 05/10/19 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
I won't go over about 80% of what the factory says it can tow, for fully loaded trailer weight. There is "it can tow it" and then there is "it tows it comfortably and I will actually use it". If it is not comfortable to tow, why buy it ?
2014 F 150 ecoboost
2010 F 150 4.6L
2007 ranger
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
downtheroad
Pacific Northwest
Posted: 05/10/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
....and you are going to have about 800 lbs of tongue weight...
Payload of your tow vehicle is really more important than what it can tow.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
bikendan
Camano Island, Wash.
Posted: 05/11/19 01:17am Link  |  Quote  |  Print  |  Notify Moderator
x2!
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Jebby14
Windsor Ontario
Posted: 05/11/19 04:19am Link  |  Quote  |  Print  |  Notify Moderator
yes, gvcc is the number you should work with (weight of trailer and all the **** in it) stay withing your towing capacity but more so worry about carrying capacity (payload)
payload - tongue weight(gvcc x 0.13) - weight of everything in the car (including people) - weight of hitch (likely aroun 100 lbs) - any gear in the truck
for example my f150 has 1980 lbs payload and we will assume your trailer is 6000 loaded out (I round up for extra safety factor)
1980-780-500-100-0 = 600 left over
meaning I would be ok with a 600 lbsd payload. This is good so I can bring some firewood and bikes and coolers (beer is good but not light)
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
Big_steve
SW Florida
Posted: 05/11/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys!
What I took from the answers:
Use a vehicle that can tow more than the GVCC of the trailer.
Buy a tow vehicle with enough payload for the weight of passengers/gear in the tow vehicle/tongue weight/hitch weight.
ktmrfs
Portland, Oregon
Posted: 05/11/19 09:21am Link  |  Quote  |  Print  |  Notify Moderator
the 80% idea was IMHO appropriate 20 years ago. Back then towing at capacity often meant turning off overdrive and grunting up hills at 45mph or so.
IMHO at least trucks built in the last 10 years or more are pretty capable of running at GCVWR comfortably accelerating decently, towing hills fine. The newer engines and drivetrains have way more HP and torque than decades ago.
Often the biggest issue today is making sure you aren't over TV GVWR when you are below the claimed trailer weight limit. TV mfg assume 10% tongue weight and no cargo, while Trailer MFG design for 15% or so tongue weight. So it is easy to go over TV max tongue weight before you hit Trailer weight limit.
2011 Keystone Outback 295RE
