RV.Net Open Roads Forum: Towing: Selecting new TT Tires
Search only in Towing
Open Roads Forum  >  Towing
 > Selecting new TT Tires
twodownzero
NM
Posted: 05/13/19 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Radials. Goodyear endurance. Run far away from any chinese tire.
Cummins12V98
on the road
Posted: 05/14/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
GoodYear ENDERANCE tires have been on the market for a bit over two years with a STELLAR record!
Don't want to hear the "not long enough on the market" BS. 2 plus years and no issues that I have heard of, to me that is a good record.
I have a set on my heavy 23' GlasPly boat trailer and I tow 70 a lot with ZERO issues. My son put a set on his heavy boat trailer and traveled from NW WA to TX Summer 2017 at 75 plus with ZERO issues.
Get the "E" if you want but air to actual weights plus 5psi per GY Tech when going up in load range.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
DustyR
Posted: 05/15/19 06:58am Link  |  Quote  |  Print  |  Notify Moderator
I replaced my TT tires with Goodyear Endurance.
Coachmen Denali 270FK 32 Ft.
Tow Vehicle: 2008 Silverado 2500 HD
Duramax, Allison Transmission.
JIMNLIN
Oklahoma
Posted: 05/15/19 09:07am Link  |  Quote  |  Print  |  Notify Moderator
OP wrote:
I’m thinking that I should move up to Load Range E tires for the extra capacity.
Good idea on a trailer that size.
Should I replace just the one that failed or all 4? We probably have right around 8-10K miles on the tires, which are 6 years old.
If your tires are ST type they have timed out. ST tires that old and carrying the weight yours are carrying is a good bet others will have the same issue. We see this a lot on all the trailering websites.
Time for all new tires.
Should I consider Radials or BiasPly?
Bias ply are from another era. For a road trailer the radial tire is the way to go.
The Endurance and Carlisle HD have been out for around two years and so far are popular. Neither has been around long enough to see what kind of service record they will have for the long haul (4-5 years and 20k-30k miles). I'm betting both will have a much improved service record.
The Providers have been out since the '10/'11 era are the first of new gen higher speed rated ST class tires. Like many new ST/LT class tires they became popular on haulers webs first and finally trickle down to rv forums.
I have a 10k car hauler (9460 lbs on the axles) with Provider ST235/80-16 E tires with 30k-32k miles on them. I just got off a 623 mile run on a job at 70-75 mph speeds. After 5 years of trouble free service I'm looking to replace them with same.
CALandLIN
SC
Posted: 05/15/19 11:46am Link  |  Quote  |  Print  |  Notify Moderator
RVIA has come out in support of that statement by recommending all of their members - about 98% of all RV trailer manufacturers - to start using radial tires on all wheels 13" in diameter or larger.
Click Here!
The LeRoys
St Petersburg, FL, USA
Posted: 05/17/19 10:10am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like Goodyear Endurance is the way most are going.
I ordered a set of 4 and have them scheduled to be installed by Goodyear at my house on Monday.
Brian & Evie LeRoy and our 4 kids.
2013 KZ Spree 329IK
2006 Ford F250 6.0L
2008 Ford E350 v10
trail-explorer
NM
Posted: 05/17/19 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
lenr wrote:
.... I just put Goodyear Endurance.... They are also heavier tires than other ST and LT tires in the same size. .
Yep.
Here's a video comparing the weight of the Endurance to a Les Schwab
Bob
dodge guy
Bartlett IL
Posted: 05/17/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, replace all 4. I would highly recommend going with the Carlisle HD’s in the “E” rating. One of the best tires out there right now!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JIMNLIN
Oklahoma
Posted: 05/17/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
The LT and ST in a 235/85-16 E are about the only two that are the same size.
Goodyear says the ST235/85-16 E weighs 44 lbs.
Goodyear also says their LT E Wrangler H/T weighs 50 lbs.
Michelin same size XPS Ribs weighs 56 lbs.
Bridgestone R-238 same size weighs 59 lbs.
BFG Commercial LT E same size weighs 45 lbs.
No doubt the new Endurance is a a lot heavier than the old same size Marathons at around 38 lbs. They should do well for rv trailer use.
Earl E
Green Valley, AZ
Posted: 05/17/19 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
X2
2007 Northwoods Arctic Fox 32 5S Fifth Wheel used for fulltiming for several years--SOLD
2014 Sunnybrook 26rl to poke around the smaller parks in the great Southwest
2007 Chevy Silverado 2500 HD Diesel
Prodigy brake control
