RV.Net Open Roads Forum: Travel Trailers: Sunnybrook Edgewater 2009 Roof
 > Sunnybrook Edgewater 2009 Roof
monksblood
sask
Posted: 05/12/19 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
As there is no ladder on the back of our camper does anyone know if I can walk on the top of the camper or should I use plywood to distribute my weight. I want to get up there for cleaning and to check the sealant
Lone Pine, CA
Posted: 05/12/19 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
IMO never walk on your roof unless absolutely necessary. Most work can be done from a ladder. I’ve never needed to walk on an RV roof to clean it. If you must, what does the manufacturer say...walkable?
* This post was edited 05/12/19 08:42pm by Lwiddis *
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
gaymeadowsman
Montgomery, Alabama
Posted: 05/13/19 07:10am Link  |  Quote  |  Print  |  Notify Moderator
It's always best to err on the side of caution. But if you can tell where the rafters are located that will also give you extra support. None of my trailers have had ladders and I've been on all the roofs, even our old Ultra Lite. I weigh 210 pounds. I always step on rafters and walk as close to the edge as I safely can.
John ">
Ted ">
2014 Prime Time Avenger 27RLS Touring Edition
2010 Chevy Silverado Ext Cab LT
2015 Chevrolet Impala LT
Dick_B
Palos Heights, IL USA
Posted: 05/13/19 08:25am Link  |  Quote  |  Print  |  Notify Moderator
You might ask this question on the Sunnybrook users forum at www.myrvtalk.com. Sunnybrooks were pretty well made. I walk on my roof all the time.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
lcirelli
Marshville, NC
Posted: 05/16/19 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Hi, I have a 2008 Sunnybrook Edgewater. It does have a walkable roof. My husband is up there all the time. No problems.
2008 SunnyBrook Edgewater 266RBE
2015 F250 Superduty SuperCab XL 6.2 V8
2011 F150 EcoBoost Super Crew Max Tow Pkg 3.73
mosseater
Dillsburg, PA
Posted: 05/17/19 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I don't recall if all their line had a walkable roof, but our 08 is. I've been up there and it seems fine as long as you're careful and think light thoughts.
Sunset Creek 298 BH
TurnThePage
North ID
Posted: 05/17/19 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with the "pay attention to where you step" crowd. My trailer manual specifically mentioned that it does NOT have a walk on roof, but after 15 years I've had to walk on it quite a few times. I've also learned that "walk on" is less harmful than "stand on", where all your weight is concentrated on one spot for a long time. You can also "crawl on", which makes it easy to spread out your weight. I used to try boards or planks to spread the load, but they were more trouble than they were worth.
2015 Ram 1500
2004 Pioneer 18T6
monksblood
sask
Posted: 05/18/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the replies. It looks like being on the roof will be ok. Easier to clean and inspect
BillyBob Jim
US
Posted: 05/18/19 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Walk on roof = marketing buzzwords.
All if not most use 8mm / 5/16" plywood.
Screwed down (such as Heartland) much better than stapled (Keystone, many Forest River brands, Grand Design, and a lot of others).
Wood rafters are better for holding stapled plywood than stamped steel rafters. (Keystone again, they staple plywood to stamped steel rafters).
The more you walk on any they loosen up from the movement. When staples pull out a little they do not go back in. When staples pull through plywood and loosen they do not tighten back up.
A lot of it depends on the manufacturers means and methods.
The closest I've seen to walk on which is not marketing hype are the 4" thick laminated roofs used by Flagstaff/Rockwood as long as you don't plant your foot right over one of the routered in AC ducts that run front to back. You can do the Macarena on one of those roofs.
