RV.Net Open Roads Forum: General RVing Issues: Rubber Roof Cleaner and Protectant
 > Rubber Roof Cleaner and Protectant
pmlevine
Massachusetts
Posted: 05/12/19 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
After it stops raining here in the NE, I will be cleaning the rubber roof on my TT. I've done some research and believe the best option is to use a medium bristle brush and clean with a solution of Murphy's Oil Soap. Then when dry, apply Airspace 303 Protectant.
As always, I will appreciate what other more experienced RV's do to clean and protect their rubber roof.
TxGearhead
Posted: 05/12/19 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Wet and Forget
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
Morro Bay, CA
Posted: 05/12/19 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
That’s not what Winnebago recommends. “This rubber roof material does not require coatings to protect the surface from ultraviolet light or ozone.“
I didn’t use STP back in the day either.
lenr
Indianapolis, IN
Posted: 05/12/19 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Talked to Dicor (who makes most of the rubber roofs) at a Good Sam rally a few years ago. They recommended using their cleaner and protectant saying that the more expensive treatments are not needed.
gbopp
The Keystone State
Posted: 05/13/19 03:03am Link  |  Quote  |  Print  |  Notify Moderator
I use Aerospace 303 Protectant on everything except the roof.
And, with all the rain, I don't think it will be necessary to clean the roof IF it ever stops raining. My roof looks pretty good.
2012Coleman
Posted: 05/13/19 05:05am Link  |  Quote  |  Print  |  Notify Moderator
I was given CamCo roof cleaner available at Walmart. It sat on the shelf for a long time, but then I went to clean the roof and didn't have my usual Spic & Span so I used it. Was not enthused while cleaning, but the rinse water was brownish. But when it dried, boy what a difference - very white and bright. Here is a picture I used for selling it taken after cleaning it and laying down caulk. I use a soft brush on a threaded pole.
* This post was edited 05/14/19 04:24am by 2012Coleman *
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
pmlevine
Massachusetts
Posted: 05/13/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
Here is a photo of the rubber roof on my TT, discolored from weathering. It at least warrants cleaning - just hosing down is not an option. I'm still not sure if/what UV product to use afterwards.
LarryJM
NoVa
Posted: 05/13/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
TxGearhead wrote:
Wet and Forget
Same here, IMO scrubbing and rubbing only shortens it's eventual life.
The only time I would do anything is if and when grass and weeds started growing from the dirt build up[emoticon]
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
LarryJM
NoVa
Posted: 05/13/19 06:28am Link  |  Quote  |  Print  |  Notify Moderator
That roof looks great and doesn't need a thing. LEAVE IT ALONE!!!!
Larry
jplante4
Cape Cod
Posted: 05/13/19 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Considering that you've had roof issues, I recommend and good cleaning and refresh of any questionable Dicor. Clean the area around where new Dicor needs to go with mineral spirits.
ProtectAll
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
