RV.Net Open Roads Forum: Where does the weight go to when using wd hitch?
 > Where does the weight go to when using wd hitch?
path1
Varies with weather
Posted: 05/12/19 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
If tongue weight scale says 930 pds and then you hook up to to hitch ball and then load up wd spring bars...what happens? Where does that 930 pds go?
wnjj
Cornelius, Oregon
Posted: 05/12/19 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
Practically speaking, some goes onto the tow vehicle front axle and some goes onto the trailer axle(s).
Technically speaking though, all of it stays there but the WD hitch creates an upward force at the ball which is countered by added downforce at the tow vehicle front and trailer axles. This lightens the effect of the trailer’s tongue weight on the rear of the vehicle.
path1
Varies with weather
Posted: 05/12/19 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for info. Washing tow vehicle this weekend,the stock hitch label says 1000 max tongue weight. Never had a problem (and safe for now) but think I'll get bigger rating hitch.
Thanks.
valhalla360
No paticular place.
Posted: 05/13/19 01:27am Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
Hitches typically have two ratings...with and without WD.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
sgfrye
north carolina
Posted: 05/13/19 06:21am Link  |  Quote  |  Print  |  Notify Moderator
good explanation
SoundGuy
S Ontario
Posted: 05/13/19 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Here you go - How Weight Distribution Works - 18 pages, when you have the time to wade through them all. [emoticon]
Mojave, Kern County, California
Posted: 05/13/19 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Bigger isn’t always better. If within a hitch limit...without WDH and with, you’re fine.
GrandpaKip
Flat Rock
Posted: 05/13/19 06:55am Link  |  Quote  |  Print  |  Notify Moderator
It goes “poof” and disappears, according to the RV salesman who sold my kids their first camper.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
APT
SE Michigan
Posted: 05/13/19 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Here is a typical example:
Dead TW: 1000 pounds
Drop tongue on ball:
TV Rear axle increases by 1400 pound
TV front axle decrease by 400 pound
Apply and adjust WD for 100% front axle restoration:
TV rear axles increased by 800 pounds from unhitched (decrease of 600 from no WD)
TV front axle same as unhitched
Trailer axles increased by 200 pound
2017 Subaru Outback 3.6R
ppine
Northern Nevada
Posted: 05/13/19 07:56am Link  |  Quote  |  Print  |  Notify Moderator
The WD applies upward leverage in the joint between your RV and the TV.
