RV.Net Open Roads Forum: Fifth-Wheels: Rancho 9000's or Bilsteins?
 > Rancho 9000's or Bilsteins?
Crabbypatty
Long Island, New York
Posted: 05/14/19 03:41am Link  |  Quote  |  Print  |  Notify Moderator
The votes are overwhelmingly for Bilsteins. My Platinum Ford is not lifted so Im going to order the 4600's. Also considering some kind of steering stabilizer as I have had a couple of death wobbles. While it may not cure it all, I dont see how it could hurt. Towing the biggest thing yet and while it rides smooth, I would like to have the odds in my favor.
Thank You for your input. Happy Trails
John, Lisa & Tara">">">
2015 F250 4x4 Platinum, 6.2L 6 spd 3.73 gears, Reese 12klb w/dual cam, Prodigy, Sunny Brook Sunset Creek 298 BH, Trojan 125's, 448 watts Solar Morning Star 45, Honda EU3000, Dish TV, Xantrax Pure Sine 2000, Wilson Cellular Ant/Amp
BarabooBob
Baraboo, WI
Posted: 05/14/19 05:22am Link  |  Quote  |  Print  |  Notify Moderator
I put Bilsteins on my Class C and drove it over 40,000 miles. They greatly improved the ride and handling. When My truck needs shocks, they will be Bilsteins.
Bob & Dawn Married 31 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
RAS43
Littleton,CO
Posted: 05/14/19 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Crabby,
When I replaced the OEM shocks on my truck with Bilsteins I also replaced the steering stabilizer with a Bilstein. It made a big difference all around.
JIMNLIN
Oklahoma
Posted: 05/14/19 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Rancho 9000 adjustable for a working truck. Bilsteins just won't hold up in this type of daily work. Bilsteins are popular on rv websites though so take your pick.
Cummins12V98
on the road
Posted: 05/14/19 09:38am Link  |  Quote  |  Print  |  Notify Moderator
FishOnOne wrote:
I had the adjustable Rancho's on my Super Duty and they lasted ~20k miles.
Please tell us what you replaced them with?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
FishOnOne
The Great State of Texas
Posted: 05/14/19 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
The factory Ford Rancho shocks. Having said that I'm going to install Bilsteins soon.
* This post was edited 05/17/19 05:38pm by an administrator/moderator *
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
FlatBroke
CO/AZ
Posted: 05/14/19 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Went from Ranchos 9000 to Bilstiens last year, never had a ride like this ever with and without the fifth wheel. No crawling under the truck again. Every time I get in the truck I smile it rides so much better and I’ve had it for 17 years.
Hitch Hiker
"08" 29.5 FKTG LS
Cummins12V98
on the road
Posted: 05/14/19 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the honest reply!
But how can you justify a foreign owned American Made shock?
Willcamp4
Nevada
Posted: 05/14/19 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have had two Super-Duty trucks. Both were F-250s, and the first was a 2000. Along with my current 2012 I looked at the same question. With both I installed Air Lift brand rear air bags, although I have also heard good things about Firestone. You can do a system that just uses the schrader valve to control the pressure in the system, but having an on-board compressor with the remote control is great. With the current system I am using the Wireless One remote controller, and it works great. Just a tip; if you have the upfitter switches you can consider wiring it to one of the switches so you can turn the system off while hitching/unhitching. I used #4.
About the shocks. I installed Rancho RS9000 shocks on both trucks. On my 2000 the first set lasted about 150K before they were shot. I installed another set on the truck that were still working great when I sold the truck at 220K miles. I also put a set on my 2012 last year and they were a big improvement over the so-called Ranchos that came with the truck. The factory shocks never were very good, so I don't know what model they really were; probably RS5000. The best advantage of the RS 9000 is the adjust-ability; you can change the adjustment for whatever your use is. I am very happy with them. I can't speak for Bilstein.
Willcamp4
2012 Ford F-250 Super Duty, Crew Cab, Lariat, 6.7L PSTD, Air Lift rear suspension.
Alpenlite Valhalla Limited Fifth Wheel, two Solar panels, four six-volt batteries, two Honda EU2000i generators
slapshot12
FL
Posted: 05/16/19 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
My truck is stock and the 5100’s work just fine. The ride height is the same and the ride is great. I also installed a Fox single steering stabilizer and that was a huge improvement also. Very easy install.
Word of warning...Anyone that has a ‘17+ Ford Super Duty and a B&W Turnover Ball hitch, the right rear shock is a major pain in the arse. The upper shock mount is about 1” from the hitch. I had to loosen the hitch, slide it to the driver’s side, and still barely got the shock in.
'18 Momentum 349M
'17 F-350 SRW Lariat CCSB 6.7 FX4
