RV.Net Open Roads Forum: General RVing Issues: Water leak through Air Conditioner...
 > Water leak through Air Conditioner...
mgirardo
Brunswick, GA
Posted: 05/13/19 07:22am Link  |  Quote  |  Print  |  Notify Moderator
This morning I discovered a "leak". A small puddle in the kitchen under the A/C unit. It rained most of the day yesterday and it's been raining most of the morning. I went on the roof and could not find a tear or puncture on the roof anywhere around the A/C unit. I was just on the roof the other day inspecting it and found no issues the either. We have had a lot of rain the last few weeks and have not found any water inside, we camp seasonally and have been in the unit since the end of April. The puddle is in the path of the bunkhouse and if we had a puddle before it would have been found with the kids going back and forth to the bunk house.
I pulled the cover off the A/C unit inside the camper. The wood all around the opening is dry and there is no obvious signs on the wood that water has leaked in the past. The water appears to be coming in through the opening where the fan is (circled in the photo below). All up in that area was wet. The foam divider is dry.
Since it was raining, I did not pull the roof top shroud to take a look. I am going to cover it for the time being as it is supposed to rain for the next 24 hours or so and we have to go out of town for a few days.
Without seeing photos of the top side of the unit, does anyone have any ideas where the water could be coming in? It hasn't been warm enough to run the A/C, so I don't know if it is functioning properly or not.
One thing I did notice after I discovered the puddle, it really started to drip when the furnace kicked on and it wasn't raining very hard. Right now it is a steady rain and there is no dripping. Could it just be condensation build up? It was chilly last night, mid 40s and the heat is set to 72. There is no condensation on the windows.
Thanks in advanced,
-Michael
* This post was edited 05/13/19 02:01pm by an administrator/moderator *
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Ranger Smith
Wherever the rig is parked
Posted: 05/13/19 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Either a plugged condensation drain tube which you access by removing outside cover or the mounting bolts inside need to be tightened slightly.
Where we are now
Amateur Radio Operator WW1SS . . . Expert Electronics MB-1 , K3, P3 and KPA 1500,Icom 7100
Steve and Joy
2012 Winnebago Tour 42JD . . . 2016 Ram 1500 4x4 Toad
Cooper ... The Doodle,
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
ItsyRV
Desert SW
Posted: 05/13/19 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I agree, it's most likely a clogged condensation drain. There is also a chance of a break in the seals around the blower housing. This would cause water to enter the blower housing from the rain. Regardless, up to the roof you go as the shroud will need to be removed to clean the unit and/or to seal the unit.
* This post was edited 05/13/19 08:15am by ItsyRV *
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
Bobbo
Wherever I park
Posted: 05/13/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
The Winnebago I bought in 2007 had a leak like that from the day I bought it. I finally tracked it down. The AC unit sits on a rubber or foam gasket. The 4 bolts in the corners of your photo that pull down on the AC unit weren't tight enough. I tightened them to pull the AC unit down about another 1/4 inch and the leak stopped, never to return. Didn't even have to go up on the roof. DO NOT CRANK IT DOWN AS TIGHT AS YOU CAN AND SMASH THE GASKET.
Bobbo, Linda and the furry kid (45 pound rescue)
alfredmay
West Milford, NJ / Donna, TX
Posted: 05/13/19 10:00am Link  |  Quote  |  Print  |  Notify Moderator
The very first thing to do is what Bobbo stated.
Alfred May
2005 Excursion V10 4.30 4x4
2002 Cedar Creek 30RBS TT by Forest River
Reese Dual Cam
Tekonsha Prodigy
Old-Biscuit
Verde Valley
Posted: 05/13/19 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Leaking when running A/C Unit or right after you shut it down....evap coil drip tray overflowing due to clogged drain lines
Leaking when raining.........loose A/C Unit and roof rain water is leaking past roof gasket
The 4 hold down bolts need to be 'snugged' up (snugged up means 40 INCH LBS....in other words just slight tightening past finger tight)
Wherever I happen to park
Posted: 05/13/19 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
That is ... if I"m not mistaken the cold air outlet. IF THE AC was on it might have just been condensation.... But the drip tray and water path to the roof (And then to ground) is a good choice too. Almost no way for water to ENTER via that. has to be condensate.
Home is where I park it.
turbojimmy
New Jersey
Posted: 05/13/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
If you had been running the a/c I'd guess a clogged drain tube at the catch pan. But if you haven't been running the a/c, the leak is probably elsewhere and finding its way to the opening for the a/c. You can try snugging down the bolts that hold the a/c to the roof but even if they're loose the weight of the a/c usually keeps the gasket compressed enough to prevent leaks.
1984 Allegro M-31 (Dead Metal)
RGar974417
Robesonia,Pa 19551
Posted: 05/13/19 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
It could be leaking in through the gasket that is between the A/C unit and the roof.That happened to one of our old units. The gaskets are pretty cheap and easy to install.
Egor'sRV
Port Neches,TX,USA
Posted: 05/13/19 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar leak on a brand new unit just installed.
It sat for days in the rain, not running, and had no leaks. Ran it for several days after the rain and had no leaks.
Then ran it one night during a rain and found everything under it wet and water on the floor. Couldn't find anywhere the leak could be coming in. Did notice that there was no leak if the unit wasn't running; only leaked when unit ran during a rain.
Took it to a qualified dealer who said that the fan was strong enough to pull a vacuum on the inlet side and was drawing rain water from the outside from the pan. He pulled the cover from the top and caulked all around the shrouds of both evaporator and condensing coils to keep the fan from sucking in water. Said was a common problem.
Haven't had a drop of water leak since.
"Of all the things I have lost during my lifetime, I miss my mind the most."
