RV.Net Open Roads Forum: Travel Trailers: Tongue Weight, Silverado Hitch Class
 > Tongue Weight, Silverado Hitch Class
jay427
Anoka, Mn
Posted: 05/13/19 11:57am Link  |  Quote  |  Print  |  Notify Moderator
2 questions,
Anyone know what the factory hitch class is on my 2011 Chevy Silverado 1/2 ton crew cab with trailer package?
According to the manual I have a tow rating of 9,600 if recall correctly (sorry manual is at home) that would leave me to believe that I should have at least a Class IV hitch good for 10,000/1,000 without a distribution hitch.
Think I would want/need a distribution hitch with the following trailer specs?
Length 21'-6"
Dry Weight 3309
Cargo 1091
Hitch Weight 520
Link of new Rig
Not sure if that hitch weight includes battery, propane,etc. my guess it does not.
If its a class III will need a distribution hitch, if class IV we are within specs.
The last camper we had (7 or years ago) had a Equalizer Hitch, would go the same way unless someone has a better option.
Thanks all,
Jay
ktmrfs
Portland, Oregon
Posted: 05/13/19 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
factory trailer hitch weight is almost always with an empty trailer, no battery(s), empty propane tanks as it rolls out the door. In my case loaded tongue weight is 1450lbs with full water tank, 4 batteries, full propane.
Empty tongue weight as new (which I verified) 800ish lbs. Now 4 GC2 batteries adds around 300lbs right off the bat. stuff on the tongue may as well figure directly adds to the tongue weight, it's so close to the coupler.
On the WD hitch, if you are happy with equalizer, keep it. It's a quality system, especially if you already have one.
2011 Keystone Outback 295RE
jay427
Anoka, Mn
Posted: 05/13/19 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
Wish I would have kept it, sold it with the old rig about 7 years ago. After doing a quick search I see a few more manufactures now offer similar systems.
Boomerweps
Hills of PA
Posted: 05/13/19 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Not enough specific info.
I did a quick search using 2011 Chevrolet Silverado 1500 towing package and the factory PDF towing Gu?i?d?e was one of the first listings.
You need the engine, GVWR from the door sticker and that towing Gu?i?d?e for your answer.
Most half ton truck hitches (class IV) I've seen are only rated for 500 tongue weight and 5000 pulling/tow weight when used WITHOUT a WDH. WITH a WDH, they are rated to 10,000 or a bit more.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
Boomerweps
Hills of PA
Duplicate
OleManOleCan
Alabama
Posted: 05/13/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I found out the hard way that some Silverado's sold as HD were not ...
In 2008 I bought a new Silverado that turned out to be a major disappointment.
Mine was underpowered, and not HD.
I towed a 8500 lb camper to the Smokey Mts. I came home and traded for a F-250
Diesel. It really was HD, and towing was easy.
It first I thought my Equalizer was set up wrong... That was one of the things that actually was as advertised.
Not looking at your rig... I'd say a good Equalizer and strong truck could fix most problems.
jay427
Anoka, Mn
Posted: 05/13/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
From the manual,
5.3L V8 K5L HD Cooling Pkg, Axel Ratio 3.42, Max trailer 9,500 lbs. GCWR 15,000 lbs.
After all of this I found the dang spec, sorry all.
Its 600lbs without WD and 1,100 with WD!
Its so close may as well get the WDH, now what one? Should have kept our old 2500!!!!
owenssailor
Ontario
Posted: 05/13/19 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 2012 Silverado with the same specs as your 2011. I towed a 6700 lb (loaded) trailer all over the South part of the continent. I had an Equalizer hitch. The combination worked very well. Get the hitch that will handle 7-899 lb tongue. That would be the 1000/10000 model.
2011 Jayco 28U
2012 Chev Silverado Crew Cab 5.3 6 spd 3.42 (sold)
2017 Chev Silverado Crew Cab 5.3 8 spd 3.42
Equal-i-Zer 1400/14000
RotoChocks
jay427
Anoka, Mn
Posted: 05/14/19 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Good news, thanks
ppine
Northern Nevada
Posted: 05/14/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Read the label on your trailer hitch.
could go either way. You probably won't need a WD.
