RV.Net Open Roads Forum: General RVing Issues: Broken/ leaking exhaust manifold bolts
 > Broken/ leaking exhaust manifold bolts
fourthclassC
MA
Posted: 05/23/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Well I do almost all my own work on everything. Here's a clue if you attempt it. Remove the wheel (from the side with the broken bold/stud) and remove the inner fender. (usually held in with plastic fasteners) Greatly improves access. Also another vote here for using alternative method (weld nut on) because I have never had success with an easy out.
CavemanCharlie
Storden,MN
Posted: 05/23/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Dtank wrote:
theoldwizard1 wrote:
azdryheat wrote:
It's somewhat easy to do but get a mechanic if you don't know what you're doing.
ABSOLUTELY !
I have been a "shade tree" mechanic for almost 50 years, and replacing an exhaust manifold and studs/bolts is something I would never attempt (except in my broke/stupid youth) !
If it means driving for a couple of more weeks while you save up the money, it will be worth it !!
After reading your thread-starter post.......
X-2 on "ABSOLUTELY".
Pay "the freight" (the mechanic) - and save the grief (yours).
X3
If you try yourself and make it worse it will cost even more. Maybe a lot more.
A easy out will work in some cases for some things but, not with manifold bolts. They have been heated and cooled through many cycles. They are dammed stuck.
It's might cost some dough to get it fixed. Might have to remove lots of stuff to get to them. If it's been leaking for awhile you might need to have the manifold removed and plained.
Or, you might get lucky and the mechanic might get them right out.
Don't try it at home in any case.
weasel4
Alberta
Posted: 06/01/19 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
All bolts should be tightened to the proper torque, not just using an, it appears tight enough method.
mike brez
Unknown
Posted: 06/03/19 06:15am Link  |  Quote  |  Print  |  Notify Moderator
So any luck? did you get them out or bring it somewhere?
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
SpeakEasy
Western New York
Posted: 06/03/19 06:41am Link  |  Quote  |  Print  |  Notify Moderator
"You've got to know when to hold 'em,
Know when to fold 'em,
Know when to walk away;
Know when to run..."
-Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
mike brez
Unknown
Posted: 06/03/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Guess I'm a gambler. Had leaking manifold bolts on my 1994 PaceArrow when it was 21 years old. Soaked the bolts and studs for a week spraying a few times a day with a mixture of aceatone and transmission fluid. Everyone came right out and replaced with ceramic coated Doug thorly headers.
Recently just replaced my turbo charger on the motorhomeHere and did the same soaking procedure and all nuts came right off.
