RV.Net Open Roads Forum: General RVing Issues: Broken/ leaking exhaust manifold bolts
 > Broken/ leaking exhaust manifold bolts
Matt_Colie
Southeast Michigan
Posted: 05/14/19 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Teddy,
This repair is a sure way to end up in more trouble than you had before. If there is a KAP that will do the job, go that way, but its long term survival is doubtful.
We do not know anything about your rig and we don't need to for this. But, if you as an inexperienced person try to remove the failed fastener, I give you about a snowball's chance of making things better.
A big part of the problem is that with the engine in the rig, there is very limited room to work. People that do this every day have both experience and a bunch of learned cheap tricks that can make a big difference.
What ever happens, put everything back together with low grade fasteners (SAE gr 2) and slather it all with nickel base anti-sieze. That is because you will be taking it apart again and alloy fasteners do not like the temperature of exhaust things.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
theoldwizard1
SE MI
Posted: 05/14/19 08:30am Link  |  Quote  |  Print  |  Notify Moderator
azdryheat wrote:
It's somewhat easy to do but get a mechanic if you don't know what you're doing.
ABSOLUTELY !
I have been a "shade tree" mechanic for almost 50 years, and replacing an exhaust manifold and studs/bolts is something I would never attempt (except in my broke/stupid youth) !
If it means driving for a couple of more weeks while you save up the money, it will be worth it !!
parker.rowe
Delaware
Posted: 05/14/19 09:37am Link  |  Quote  |  Print  |  Notify Moderator
If it is the bolts that hold the manifold to the head, this a a common issue on the LS series. Not sure about the 8.1's....do they have aluminum heads?
The aluminum head LS's are pretty easy from what I hear. My friend has done a few. You just weld a nut to the broken bolt. The heat loosens it up and the nut lets you take it out. And you don't have to worry about welding the nut to the head accidentally because it's aluminum. He says they are no problem...I've never done one.
If it the the stud/bolt that connects the manifold to the rest of the exhaust, I would probably just replace the manifold. I don't think they are that expensive.
If you can install headers, you can do this. Might get the blood pressure up a bit your first time, but it's not rocket surgery. [emoticon]
2015 Starcraft TravelStar 239TBS 6500 GVWR
1996 GMC Suburban K1500 5.7 Vortec/4.56 Gears/PCM4Less Tune
1977 Kawasaki KZ1000
ZINGERLITE
Union Lake
Posted: 05/14/19 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Dave H M wrote:
X3 here on the easy out. If you go there once, that will be the first time and last on what to do next after the easy out snaps [emoticon]
Machinist friends ive known always say that the best thing to do with an easy-out kit it throw it in the trash.
tdiller
usa
Posted: 05/14/19 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
I'm pushing 60 and in all those years I have never had an easy out work. I gave up on them after the first few tries left a broken easyout where the stuck bolt once was. Now I let me son the mechanic do the work.
fj12ryder
Platte City, MO
Posted: 05/14/19 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, if you don't know how to use one it's the best thing to do with it. OTOH if you do know how to use one, then they are very handy, and, dare I say, indispensable in some cases.
And there really is a technique to lessen the chances of braking an EZ-Out. Unfortunately, just techniques, no guarantees. [emoticon]
Howard and Peggy
"Don't Panic"
Eric&Lisa
Scappoose, OR
Posted: 05/16/19 11:45am Link  |  Quote  |  Print  |  Notify Moderator
I recently had four bolts (out of six) snap on the lower unit from an outboard motor. They were a real PITA to drill out and re-tap. That is with the lower unit in a vice on my work bench. I can't imagine trying to do the same thing to an exhaust manifold bold in the confines of an engine compartment. Something goes wrong, and it goes from bad to worse - unable to drive the vehicle to a mechanic.
I am a avid DIY person. However, there are some things where the amount of frustration incurred will outweigh the DIY satisfaction. Exhaust manifold bolts, with the motor in the vehicle, are one of them.
+1 to spend the money with the mechanic.
HTH,
-Eric
Eric & Lisa - Oregon
'97 Silverado K2500, New HT383 motor!, Airbags, anti-sway bar
'03 Lance model 1030, generator, solar,
gkainz
Arvada, CO, USA
Posted: 05/17/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
sign in a shop ...
"This 1 hour job is 1 broken bolt away from becoming an 8 hour job"
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
Dtank
Posted: 05/20/19 11:26pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
ABSOLUTELY !
After reading your thread-starter post.......
X-2 on "ABSOLUTELY".
Pay "the freight" (the mechanic) - and save the grief (yours).
Bipeflier
Centralia, MO
Posted: 05/21/19 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Exhaust systems and sewer systems are 2 things I won't mess with. Neither ever go well. Leave it to a professional.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
