RV.Net Open Roads Forum: Travel Trailers: Wobbly dinette table
 > Wobbly dinette table
sherrycalh
Posted: 05/14/19 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Morning... We just purchased a used RV. The dinette table is located on a slide. It's on 2 pedestals. One is obviously not attached to the floor well. The table is very wobbly. How do we fix this situation?
scbwr
North Ridgeville, OH
Posted: 05/14/19 06:30am Link  |  Quote  |  Print  |  Notify Moderator
The first thing to do is just check any screws on the mounting plates (floor and bottom of table) and make sure they are tight. If they are tight, or table is still wobbly, check the length of each leg. If the legs are removable, remove them and see if they are the same length. If the leg ends are damaged or bent, you can buy replacements.
You may get better advice if you can attach some photos as there are different styles of tables and mounting hardware.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
jerryjay11
Dover
Posted: 05/14/19 06:43am Link  |  Quote  |  Print  |  Notify Moderator
If you have checked what was said above and still wobbly you may just have to get use to it as these tables mounted on two posts are always a bit wobbly. It's inherent of the mounting hardware.
cavie
Posted: 05/14/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Remove the screws and the plates. pack the holes in the floor with tooth picks or slivers of ceder shims. Add some Elmer's glue and replace the plates and screws.
GordonThree
Northern Michigan
Posted: 05/14/19 07:12am Link  |  Quote  |  Print  |  Notify Moderator
x2 on this. screw holes are probably worn and not holding tight anymore.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
Bols2DawaLL
SW. Ontario
Posted: 05/14/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
3 new threads asking the same question ?
2012Coleman
Posted: 05/14/19 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Give it a rest - I'm sure a mod will be along to fix it.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
pianotuna
Regina, SK, Canada
Posted: 05/14/19 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Hi Sherry,
Welcome to the forums.
I'd suggest packing the screw holes with Kleenex, then soak in some water thin CA glue. Mark the holes using the receivers as template. Next start the screws on the marked spots. Finally put the receiver in place and gently tighten the screws.
There will be some wobble with dual pedestal tables--but the nice part is most things left on the table may not 'walk off' while driving.
Regards, Don
pianotuna
Regina, SK, Canada
Posted: 05/14/19 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Duplicate post
trail-explorer
NM
Posted: 05/14/19 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Install bigger screws
Bob
