RV.Net Open Roads Forum: Travel Trailers: Wobbly dinette table
 > Wobbly dinette table
Vintage465
Prunedale CA.
Posted: 05/14/19 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
myredracer wrote:
sherrycalh wrote:
myredracer wrote:
The typical RV pedestal legs do wobble quite a bit regardless. There are some ways to replace the legs with something better which is what we did.
YES, that is what our flange looks like. Only one is loose on the floor. What did you use that was better?
We have aluminum table legs that Lance uses as in this photo. The flanges are much wider. VERY solid and almost no wobble at all. They look nice too. They are made by Tacomarine.com. They don't sell to the public but you can get them from a marine store or a Lance dealer.
On a previous TT I took the standard pedestal legs out like you have and mounted a bracket at end of the table to the wall and a folding leg. Both are standard RV accessory items. Only thing with this is you're left with holes in the floor from the flange. Not a problem in our case because I also installed new plank flooring. If not fussy, you could always use a little dab of vinyl flooring seam sealer in the holes.
That set up from Tacomarine is really great. I was able to remove two of the crummy chrome steel posts and replace it with one of those. So, so, so much better. I ordered them through a marine supply online that I can't seem to recall the name of!
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retiring in 2021, then look-out road, here we come!
sherrycalh
Posted: 05/15/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Thanx everyone.. going to try removing and replacing in new holes that will be spaced in the middle of the booth area and closer to the wall. We do have booth seating opposite each other. Never had a slide before.
Table is mounted on carpet. Hope we can see the old holes to fill. Toothpicks and glue?
ppine
Northern Nevada
Posted: 05/15/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
myredracer has shown a photo of the new style of flange that is commonly available. There is an older larger flange with more screw holes that used to be common. The hole diameter of the flange is slightly different.
D.E.Bishop
Eagle Rock, CA
Posted: 05/15/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
As yours are mounted on a carpeted surface and you will re position both bases, don't worry about filling the original mounting screw holes. If you can't see them, no one else can either.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
D.E.Bishop
Eagle Rock, CA
