RV.Net Open Roads Forum: Fifth-Wheels: Finding 12v wires for vent fan
 > Finding 12v wires for vent fan
rjsurfer
North Carolina
Posted: 05/14/19 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
What's been people's experience when adding a powered fan to replace a manual vent with no fan when, when it comes to finding the 12 volt leads in the roof.
Does Keystone run the wires nearby or will I be forced to fish them from a ceiling light?
My model is a 2019 25RES.
Thanks
Ron W.
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
opnspaces
San Diego Ca
Posted: 05/14/19 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
It's possible your unit has an option of a powered vent in that location. I would pull down the inner trim if any and see if you can see wiring there.
If no wiring you might have to get creative. Can you use a metal coat hanger to reach from the vent location over to one of the ceiling lights? If so they pull the light down and tap a wire into the light fixture and use the coat hanger to pull the wires over to the vent location.
Last ditch is to use some decorative raceway from somewhere like Home Depot and run the wire up a wall and across the ceiling.
Link
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Puttin
Martinez, Ca
Posted: 05/14/19 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a light fixture within a foot or so of the vent opening you can just use a coat hanger and bend a hook at one end. You're just going to be fishing through some Styrofoam to intercept a set of 12v wires. Then just tap into the hot side before the light and jumper it back to the fixture...same with the neg side.
keymastr
S.E. Washington
Posted: 05/15/19 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Not a Keystone but mine had two loops of wire next to the vent, pos and neg. Just had to tap in to the loops. [emoticon]
