RV.Net Open Roads Forum: Class C Motorhomes: Need A/C Help
 > Need A/C Help
BODYGUARD_29
Peoria, AZ
Posted: 05/14/19 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
I recently purchased a 2015 Coachmen Leprechaun about a month ago. When I took it home, I plugged the power cable into my house and ran everything including the A/C and it worked fine. Today I went to do a few projects on it, so I fired up the generator and attempted to turn on the A/C, and nothing happened. I tried all the thermostat settings (fan, A/C, heater) and nothing turned on. I couldn’t even hear anything trying to activate. Any suggestions? I appreciate any help.
cavie
Posted: 05/14/19 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Did any 120 work. Have you checked the 120 volt circuit breakers on the gen?
BODYGUARD_29
Peoria, AZ
Posted: 05/14/19 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
It was plugged into a standard 110 outlet at my house. I store it offsite, so I only can use the generator where it is stored. The generator fired up fine, and the other appliances work off the generator, but for some reason, the A/C won’t even attempt to turn on.
carringb
Corvallis, OR
Posted: 05/14/19 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Is yours equipped and an automatic transfer switch? It's not standard on the Leprechauns. You might not even have a manual transfer switch. You might have to plug the shore power cord into the generator outlet.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
BODYGUARD_29
Peoria, AZ
Posted: 05/14/19 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
The plug is plugged into the generator. I can get the generator going, just not the A/C.
gbopp
The Keystone State
Posted: 05/15/19 04:14am Link  |  Quote  |  Print  |  Notify Moderator
Reset the circuit breakers on the generator. Turn off and back on.
cavie
Posted: 05/15/19 04:35am Link  |  Quote  |  Print  |  Notify Moderator
reset the A/C circuit breaker in the main panel.
Cocky_Camper
Rock Hill, SC
Posted: 05/15/19 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Check the A/C breaker in the panel box inside.
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
navegator
San Diego CA.
Posted: 05/15/19 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Depending on the generator some units also have a braker on the generator as well as a start stop switch, make sure that if it has a braker at the gen unit it is not off or tripped, and do not start the gen while hooked to shore power.
navegator
PNW_Steve
Pacific Northwet & cold
Posted: 05/15/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
I had a similar issue a few years ago.
I purchased a used TT. I built a rack on the back for my trusty Honda EU3000i generator.
When I plugged into shore power everything worked great. When I unplugged from shore power and plugged into the generator, everything worked except for the air conditioner.
I suspected that the generator had a problem so I took it to the Honda service shop. They tested it and found no problem.
Someone suggested that I install a "soft start kit". I had no idea what that was.
I found an RV parts warehouse nearby and asked them. They knew exactly what I was looking for. About $30 and half an hour on the roof installing it and the problem was resolved.
Good luck.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
 > Need A/C Help
