RV.Net Open Roads Forum: Class C Motorhomes: Need A/C Help
 > Need A/C Help
BODYGUARD_29
Peoria, AZ
Posted: 05/15/19 11:00am Link  |  Quote  |  Print  |  Notify Moderator
I did reset the breaker inside the unit. That made no difference. I haven't checked the fuse yet.
Seattle Steve
Tucson
Posted: 05/15/19 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Most AC units require 12-15 amps, and up to 50% more to start up. If you were running it off a standard 15 amp outlet, then feeding through an extension cord of too small a gauge (most are 14-16 gauge, you need 10-12) it's possible you were only getting 8-10 amps at the motorhome. It's entirely possible the AC compressor motor was damaged.
Fuses protect from too much power, not too little.
bobndot
Posted: 05/15/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
(fan, A/C, heater) and nothing turned on
Do you think it could be the fan ? I have had fan blades hang up and not spin. I gave the blades/fins a spin by hand while squirting a little lubricant on the fan shaft.
cavie
Posted: 05/16/19 05:41am Link  |  Quote  |  Print  |  Notify Moderator
Stop guessing and start checking. Use a volt meter. Measure the voltage at the A/C breaker in the panel. Turn on the T-stat. Measure the voltage at the A/C on the roof. This will require removing the cover. There is no fuse to check.
BODYGUARD_29
Peoria, AZ
Posted: 05/16/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
After doing some further research, it appears that there is a good chance that it could be the starter capacitor. Does anyone know if the capacitor will indicate it is bad, like a fuse does? If so, what is the indicator?
dougrainer
Carrolton, Texas
Posted: 05/21/19 09:58am Link  |  Quote  |  Print  |  Notify Moderator
It takes 12 volts to operate the AC controls. Do you have the 12 volt coach power turned ON? If you have ceiling lights the Power is turned on. Doug
 > Need A/C Help
