RV.Net Open Roads Forum: Travel Trailers: New Brakes
 > New Brakes
stevemorris
ontario
Posted: 05/15/19 06:12am Link  |  Quote  |  Print  |  Notify Moderator
im considering an entire brake replacement for our 12 yr old 27 ft tt
linings are glazed and 1/2 worn, drum slightly rusty, magnets are questionable
brake performance is poor
im pretty sure its never had anything new in the brake department, this is our second season coming up and we plan a 5000 mile trip
suggestions as to sources, brands etc etc
dexter leaf spring axles, 15 inch wheels, probably 10 inch brakes, have check diameter and width of course, might even be 12 inch brakes
would be even nicer to add a parking brake!!
2017 Ram 1500 4door, 4x4, 5.7 l hemi, 8 speed
2008 KZ Spree 260
blownstang01
Upstate NY
Posted: 05/15/19 06:38am Link  |  Quote  |  Print  |  Notify Moderator
E-Trailer. Just get the whole assemblies backing plate and all. Add new drums and bearings. Done.
Iraqvet05
Greenwood, MO
Posted: 05/15/19 06:43am Link  |  Quote  |  Print  |  Notify Moderator
x2 I did that to our Bobcat trailer at work last year. Etrailer is a great company.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
rrupert
NW PA
Posted: 05/15/19 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Go for the self-adjusting brakes.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
myredracer
Langley B.C.
Posted: 05/15/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Same length & weight TT as our Spree. Ours has 12" brakes and work great. I'd suggest upgrading to 12" if you have 10" now. I'd replace the bearings too.
BTW, while you're in there, inspect the plastic bushings. There's likely to be not much left of them. Maybe time to look in to Dexter equalizers and wet bolts. Also inspect the frame above the spring hangers for cracks. (The frames on the Spree's aren't all that strong.)
Oh what the heck, while you have it all apart, install a set of shocks, lol! You won't regret it. They transformed our Spree.
I hate CAPTCHA. It just will not go away...
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2012 GMC Sierra 2500HD crew cab
Lynnmor
Red Lion
Posted: 05/15/19 10:11am Link  |  Quote  |  Print  |  Notify Moderator
You probably can't upgrade to 12" brakes without replacing the entire axles. DO NOT use the Chinese bearings from E-trailer, use Timken. The bearings they sold me with the entire kit of Dexter drums and brakes were junk that failed immediately.
Self adjusting is not something that I want, it is a minor job to adjust brakes and the drums should be pulled regularly to inspect the brakes anyway.
hawkeye-08
Northwest
Posted: 05/15/19 10:57am Link  |  Quote  |  Print  |  Notify Moderator
My Dad has some brake issues on 2 yr old trailer.. he replaced controller (in truck) and all 4 brake/backing plate assemblies. He had the shop re use the drums and bearings, but the rest was all new. His problems were solved.
This was after having the brakes worked on and checked numerous times at dealer and other shops.
He just wanted to get back to camping and not fighting brake issues.
time2roll
Posted: 05/15/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Consider converting to disks. You will not regret it.
675w Solar pictures back up
Boomerweps
Hills of PA
Posted: 05/15/19 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Often there are amazon sellers selling the same items cheaper than ETrailer. Watched a few trailer brake repair Utube videos. It is very cost effective to change out the entire brake set, backing plate, drum, shoes vice just the shoes. Not a lot of time difference, either.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
carringb
Corvallis, OR
Posted: 05/15/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
I'm also a fan of the E-trailer brakes. I got the self-adjusting version.
The lining material on their shoes stops much better than the stock ALKO brake that came on mine.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
 > New Brakes
