RV.Net Open Roads Forum: Very slow propane leak: how to find it?
 > Very slow propane leak: how to find it?
Page of 5
Curly2001
Tucson, Arizona
Posted: 05/19/19 08:58am Link  |  Quote  |  Print  |  Notify Moderator
The regulators made today are junk. Mine was two years old and failed. I would guess that is the first place to look then run down all the lines and fittings. Also check the hoses to the bottles from the regulator. Some of them will leak due to the severe bends in them so check the pressed on fittings.
Good luck,
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
BillyBob Jim
US
Posted: 05/19/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Harvey51 wrote:
When I couldn’t detect a leak with soapy water spray on our old popup tent trailer I tried the very sensitive flame test using a propane torch. It clearly showed the regulator leaking.
LOL.....the old school method. Hopefully your post does not start the safety, plumbing code, and legality ramifications debate about checking a gas line with an open flame.
profdant139
Posted: 05/19/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
I'm not going to use a flame. If the source of the leak is too diffuse to create bubbles with a specially-formulated solution, it's probably too diffuse to catch fire.
And if it does catch fire, that's not so fun, either!
By the way, my old regulator was two years old. I am going to install the new one today, as soon as it stops raining. (Rain in Southern Calif in May?? Yep.)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
dougrainer
Carrolton, Texas
Posted: 05/19/19 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Old School method?????? I have over 40 years and am Licensed to service LP systems for that 40 years. In the past 40 years there has NEVER been a Flame test. Flame test is one way to win a Darwin award. You will get the medal in the Burn Ward. I am constantly amazed at the DUMB hazardly postings on these forums. Doug
BillyBob Jim
US
Posted: 05/19/19 11:25am Link  |  Quote  |  Print  |  Notify Moderator
BAZINGA!!!!!!!
And there it is LOL, further proof of a theory of mine that this forum is seriously lacking in the SENSE of humor department. Lighten up Doug, you're evidently a legend in your own mind.
dougrainer
Carrolton, Texas
Posted: 05/19/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
BillyBob Jim wrote:
BAZINGA!!!!!!!
No, Just a LOT smarter than you. Doug
PS, SOME people are just plain stupid and posts like mine help keep them safe. You would rather just watch and then brag about how you were there but did nothing but laugh.
profdant139
Posted: 05/19/19 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Well, chalk one up to my gullibility! I thought the person who said to use the flame test was being serious, and I fell for it.
Is this why they call a disagreement on a forum a "flame war?"
Anyways, we are all in agreement that flame is not a good idea. And, we're back on topic!
Jetstreamer
Milwaukee, Wisconsin
Posted: 05/19/19 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
I can’t believe that the flammable gas detector wand couldn’t find the problem for you... was it properly calibrated before use? I bought a relatively inexpensive one to trace some leaks and I couldn’t believe how sensitive it was. It sniffed out a couple of incredibly small leaks right away. Ones where I would have never smelled any gas.
BillyBob Jim
US
Posted: 05/20/19 03:08am Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
BillyBob Jim wrote:
BAZINGA!!!!!!!
Don't forget your meds today, as evidently happened yesterday.
Now that you have called me stupid twice I sure wish I would have forgone the 8 years of secondary education and went turning wrenches at an RV dealership, so you do have me in that LOT smarter regard I suppose. I would of liked to have done that for 40 years as opposed to where I ended up, being retired at 52.
* This post was edited 05/20/19 04:28am by BillyBob Jim *
JimK-NY
NY
Posted: 05/20/19 08:00am Link  |  Quote  |  Print  |  Notify Moderator
This thread seems to be going nowhere but downhill. I have some suggestions regarding the original problem with a substantial leak that has not been detected with soap or an inexpensive propane detector.
I would start with the most likely sources for a leak. Begin with the tank. I have even had a new tank that leaked. I would turn on the propane, then turn it off. If your regulator has the typical red/green markings, checking for a system leak should be easy. Pressure should be maintained for at least several hours. If the pressure remains, then the issue is the tank. If not the next area I would check is the pigtails. I have had to replace mine every few years. Hoses start to dry out and crack. Next check the regulator, then every visible propane line and fitting on the exterior of the RV. Next look at the water heater and furnace.
Page of 5
