RV.Net Open Roads Forum: Opening behind mirror base 02 Winnebago Sightseer?
 > Opening behind mirror base 02 Winnebago Sightseer?
jspringator
Versailles, KY 40383
Posted: 05/15/19 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
I discovered a little delam under my drivers side mirror. I removed the mild steel screws and replaced them all with stainless steel and a generous dollop of 3M4200. The delam appeared to get a little worse. I was wondering whether there is another opening behind the mirror base. If so I will have to either seal AROUND the mirror base or remove the mirror and seal the other opening.
Jim & Sherri
02 Winnebago Sightseer 27c Class A;
"Scout" Springer Spaniel, gone but not forgotten;
"Boo" Chocolate Labradoodle.
crawford
Dandridge Tenn.
Posted: 05/19/19 11:39am Link  |  Quote  |  Print  |  Notify Moderator
my friends same year unit was far worst it was found found cap fiberglass around top were it was attached the main body sea-let was never kept up. Check you whole front nose cap and make sure is is seal well deal told told him him he never ever check the seal, right side fix was 4 grand.
Change from a c class to a A class Georgetown 07 triple slide
