RV.Net Open Roads Forum: General RVing Issues: Anyone ever use one of these
 > Anyone ever use one of these
Walaby
Georgia
Posted: 05/15/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Wife showed me a video of filling 1lb propane tanks using an adapter like this.
Propane Adapter
Anyone use one of these? Does it work as advertised?
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
mosseater
Dillsburg, PA
Posted: 05/15/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
Guys at hunting camp use them. They say they work fine but won't fill up the cylinder completely full. I never used one so just going by what they said.
Sunset Creek 298 BH
jfkmk
NJ
Posted: 05/15/19 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like it would sure be a lot cheaper than buying the 1lb. bottles.
path1
Varies with weather
Posted: 05/15/19 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Watch some YouTube on it first. Can be dangerous. But after you do it some and dont take any short cuts, not that bad. Get thick welding cloves. Mine are from harbor freight. Dont refill at crowded places, people here a propane hiss and think worlds going to end.
GordonThree
Northern Michigan
Posted: 05/15/19 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have one of those gizmos. The idea is simple enough. It does help to have the big tank warm, like sitting in the sun for a while, and the tiny tank ice cold.
I could not get the vent open on my little 1 pounders which is an important step, need to let the air out so the liquid can flow in. Maybe 50% or less transfer without opening the vent.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
theoldwizard1
SE MI
Posted: 05/15/19 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I like this video because it addresses 2 issues !
First, safety. Note, he has a table set up OUTDOORS ! Lots of ventilation.
Second the biggest problem with refilling small bottle is getting the air out of the bottle so that you can get a full LP charge. He show a cert simple and quick way to do this !
Bobbo
Wherever I park
Posted: 05/15/19 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Like the answer you got in your other, identical, thread, I prefer the 1 gallon (5 pound) tanks. Filled and used just like the 20 pound tanks everyone is used to. I have two of them.
5 lb. cylinder LINK
Bobbo, Linda and the furry kid (45 pound rescue)
wanderingaimlessly
SOBOVA
Posted: 05/15/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Been using one for years. As others have said, you wont get tanks but about half full unless you invert the cylinders.
I attach the small tank and the turn it upside down and tilted so the small tank is pointing slightly upward using a milk crate to hold the assembly. I get tanks this way that are usually close to full. When the 20 lb tank is down to about 3 or 4 lbs left it becomes about useless.
I only get maybe 20 fills on a small tank before they start leaking, usually around the vent but occasionally from the main valve.
But doing it this way I get a filled tank for less than $1 and they are convenient for in my shed/shop.
punomatic
Pacific Northwest
Posted: 05/15/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
I think Bobbo has the right answer.
DW me, and Lulu (the Moxie with moxie!)
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
Life in Black and Blue
Walaby
Georgia
Posted: 05/15/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses.
Bobbo - the double post is a result of this website and it's service temporarily unavailable issues.
I like the 1lb bottles as I have two different grills and a smoker that use them and while I can convert them to use larger bottles, it's just easier to carry a few of the small tanks with me.
Mike
Mike
