RV.Net Open Roads Forum: Tech Issues: Electricity and electric and magnetic fields (EMFs)
 > Electricity and electric and magnetic fields (EMFs)
Page of 6
Harvard
51.6N 114.7W
Posted: 05/16/19 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Is the Electrical problem "Induced" or what?
START QUOTE:
EMFs are invisible forces that surround electrical equipment, power cords, and wires that carry electricity, including outdoor power lines.
•Electric Fields: These are formed whenever a wire is plugged into an outlet, even when the appliance is not turned on. The higher the voltage, the stronger the electric field.
•Magnetic Fields: These are formed when electric current is flowing within a device or wire. The greater the current, the stronger the magnetic field.
EMFs can occur separately or together. For example, when you plug the power cord for a lamp into a wall socket, it creates an electric field along the cord. When you turn the lamp on, the flow of current through the cord creates a magnetic field. Meanwhile, the electric field is still present.
END QUOTE:
If it is induced then it is from a Magnetic Field.
If it is capacitance then it is from a Electric Field.
Your body is 1/2 of a capacitor and unless you are off the grid, it is always exposed to an Electric Field.
For example....
maddog348
Bakersfield,CA
Posted: 05/16/19 10:27am Link  |  Quote  |  Print  |  Notify Moderator
agesilaus
North Florida
Posted: 05/16/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, what the heck? Wrong list maybe?
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
BillyBob Jim
US
Posted: 05/16/19 10:37am Link  |  Quote  |  Print  |  Notify Moderator
maddog348 wrote:
For a number of years now, work has been proceeding in order to bring perfection to the crudely conceived idea of a transmission that would not only supply inverse reactive current for use in unilateral phase detractors, but would also be capable of automatically synchronizing cardinal grammeters. Such an instrument is the turbo encabulator.
Now basically the only new principle involved is that instead of power being generated by the relative motion of conductors and fluxes, it is produced by the modial interaction of magneto-reluctance and capacitive diractance.
The original machine had a base plate of pre-famulated amulite surmounted by a malleable logarithmic casing in such a way that the two spurving bearings were in a direct line with the panametric fan. The latter consisted simply of six hydrocoptic marzlevanes, so fitted to the ambifacient lunar waneshaft that side fumbling was effectively prevented.
The main winding was of the normal lotus-o-delta type placed in panendermic semi-boloid slots of the stator, every seventh conductor being connected by a non-reversible tremie pipe to the differential girdle spring on the “up” end of the grammeters.
The turbo-encabulator has now reached a high level of development, and it’s being successfully used in the operation of novertrunnions. Moreover, whenever a forescent skor motion is required, it may also be employed in conjunction with a drawn reciprocation dingle arm, to reduce sinusoidal repleneration.
Understand?
RoyB
King George, VA
Posted: 05/16/19 10:45am Link  |  Quote  |  Print  |  Notify Moderator
I was getting small shocks one time when parking under some high voltage lines in Texas... Moved out from under the high voltage wires and it all cleared up haha...
Roy Ken
maddog348
Bakersfield,CA
Posted: 05/16/19 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Nope !! Didn't ad a durned thing to my morning.
DFord
Near St Louis, MO
Posted: 05/16/19 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Can't bother me! I'm wearing my tinfoil hat! [emoticon]
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
theoldwizard1
SE MI
Posted: 05/16/19 11:16am Link  |  Quote  |  Print  |  Notify Moderator
EMF is usually does not affect mammals.
Properly designed (and TESTED) electrical equipment does not create enough EMF to interfere with other electrical equipment.
I have spoken with people who HAVE encounter EMF (also called radio frequency (RF) interference). One was very near an extremely powerful antenna array. Another was a trucker using an illegal amplifier on a CB radio.
2oldman
Ca
Posted: 05/16/19 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I was under some high voltage lines and noticed my ladder seemed to be vibrating when I grabbed it. I measured 21 volts DC in there. Yikes.
toedtoes
California
Posted: 05/16/19 11:39am Link  |  Quote  |  Print  |  Notify Moderator
I experience it about every 6 months... my Dr sends and RF through a nerve in my neck to deaden it. [emoticon]
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Page of 6
