RV.Net Open Roads Forum: Fifth-Wheels: Andersen Hitch issue
 > Andersen Hitch issue
fj12ryder
Platte City, MO
Posted: 05/19/19 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
You really don't need the expense of an onboard compressor for your air bags. I use a 7 gallon aluminum air bubble filled to 120 psi to fill my air bags. One fill lasts for quite a few refills, and makes life easier.
Howard and Peggy
"Don't Panic"
Durb
NW
Posted: 05/19/19 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
I have an air hitch that requires I raise the front of the trailer around 2 inches for optimal unhook height. I built two 7 1/2" high blocks for under my front landing gear. I keep the outer upper tubes in the middle of their range and the lower adjustable tubes as short as possible. Never had an issue. Also helps with trailer movement and jack longevity.
gkainz
Arvada, CO, USA
Posted: 05/20/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I don't mind the extra lift to hitch and unhitch, but if you do, you could raise the hitch just enough to take the weight off the ball, then pull the pin on the ball and let it drop down into the hitch, and pull away.
Rehitching might be a bit tricky with that, however, unless you mark the exact height of the hitch.
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
Super_Dave
Harrisville, UT
Posted: 05/20/19 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve been confused by the problem that isn’t easily solved with blocks. What am I not understanding? I am in a very uneven site. The front was much lower so I used several blocks to minimize the front jack leg extension length.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Bayley
Meridian
Posted: 05/20/19 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
gkainz: That's a great idea. I'm already at the lowest pin hole but if I understand what you're suggesting, the ball unit will probably slip down in the tube a little when the pin is pulled. You're right it might be a tricky hitching up again unless I'm exactly in line with the hole in the adapter.
Super_Dave: do you have an Andersen Hitch?
Semper Fi
Tony, Darlene & the boss Bentley!
2013 Ram CTD, Ride-Rite Air Bags, B&W Turnover Ball and Andersen "Ultimate 5th Wheel Connection".
2014 Arctic Fox 29-5K 5th wheel with Reese Airborne Pin Box.
IdaD
Idaho
Posted: 05/20/19 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
My jacks seem to have enough travel available that it's never been a problem. I understand having to raise and lower a bit more than a regular hitch can be viewed as a negative, but my property isn't totally flat nor are a lot of the places we camp so I don't see it as much of an issue - my jacks get a workout regardless.
2015 Cummins Ram 4wd CC/SB
Super_Dave
Harrisville, UT
Posted: 05/20/19 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, and what confused me was not just putting blocks under the front jacks so that they have their full travel length. i.e. over a foot of travel length to get off of the ball.
Piddlers
Tennessee
Posted: 05/20/19 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Ford F-250 and use the Andersen Hitch and have no issues with it. Wish I could be of some help but we have never encountered the issue you are having.
