RV.Net Open Roads Forum: Fifth-Wheels: Converter Replacement
 > Converter Replacement
Jimfromvirginia
Virginia
Posted: 05/19/19 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
My Montana Fifth Wheel, 3455SA, appears to have lost the converter. Model number is Xantrex xadc8120. Appears this is discontinued as prices are $599 for similar from them. Seems ridiculous. Looking at a product from Progressive Dynamics, but cannot determine which one. They range from 30 amps up to 80 amps. So question is, how do you know what to put in? Thanks, trying to get ready for Holiday weekend but really struggling. Found it under the steps to bedroom, but getting to backside is going to be a pain!!!!
2012 Keystone Montana 3455SA towed by 2009 Ford F450 4x4 Diesel
dmck413
Fluvanna Va
Posted: 05/20/19 03:55am Link  |  Quote  |  Print  |  Notify Moderator
Make sure it is not just a blown fuse. Mine had 2 blown fuses once. My Heartland has a 70 amp converter if that helps.I also carry a battery charger after that time my fuses blew.
enblethen
Moses Lake, WA
Posted: 05/20/19 04:31am Link  |  Quote  |  Print  |  Notify Moderator
I would call and ask Best converter
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cavie
Posted: 05/20/19 04:48am Link  |  Quote  |  Print  |  Notify Moderator
the wattage or amperage ratting will be on the old converter. Or look it up on line. Replace it with the same or higher wattage? Kinda simple. Don't buy anything until you know for sure your converter is bad. It's called bench testing. May be as simple as blown Reverse Polarity fuses as stated above.
midnightsadie
ohio
Posted: 05/20/19 08:19am Link  |  Quote  |  Print  |  Notify Moderator
real great advice might be a simple thing as fuse corrosion .take them out of the holder and clean up a bit.
time2roll
Posted: 05/20/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Xantrex XADC 8120? Might be the distribution panel?
XADC-xx came in 40, 60, 80 amps. Most RVs error on the high side. Most would be fine with 30 to 40 amps but most typically 55 to 70 amps is installed.
https://www.manualslib.com/manual/195424/Xantrex-40-A-Xadc-40.html
I recommend the PD9260 at bestconverter.com unless you have a special situation.
675w Solar pictures back up
StirCrazy
Kamloops, BC, Canada
Posted: 05/20/19 10:03am Link  |  Quote  |  Print  |  Notify Moderator
if you have to change converter it is a good time to look at batteries if you haven't upgraded from the single one that came with the rv. size your converter to the battery bank that you want to put in.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Allworth
Orlando, FL
Posted: 05/20/19 11:11am Link  |  Quote  |  Print  |  Notify Moderator
The Progressive Dynamics 80 will handle whatever you put n it and has the charge wizard battery protection.
$300 at CW and probably less at E-Trailer and/or Amazon.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
RoyB
King George, VA
Posted: 05/20/19 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Randy at BEST CONVERTERS has the PD9200 version converter chargers that has the 14.8VDC BOOST mode modification done to them if you ever think you want to put the 6V golf cart batteries in your trailer.. The golf Cart batteries likes to see the 14.8 BOOST voltage over the old standard 14.4VDC... Cost is around $200 for the PD9260C 60AMP model... That is model I use here for charging my batteries...
Roy Ken
