RV.Net Open Roads Forum: Tech Issues: Routing Solar Wires Through Fridge Vent
 > Routing Solar Wires Through Fridge Vent
f150camper
Oregon
Posted: 05/20/19 12:07am Link  |  Quote  |  Print  |  Notify Moderator
Hi all!
I am thinking about installing a solar system on my 2012 Jayco X19H.
Have been reading a lot in the last few days, and I think that I would like to run the wiring through the Fridge Vent.
Looking under my vent today though, I see that it's closed with a wire mesh to keep critters out.
How did you get around that? I have seen somebody who had used blue sea feedthrough posts, but not sure how he even accessed the inside to secure the posts and attch the wires inside the vent.
Any pictures would really help me figuring this out!
Thanks in advance!
Nights camped 2011: 13 (4 in the old popup) ">
Nights camped 2012: 36
Nights camped 2013: 28
Nights camped 2014: 21
2012 F-150 XLT screw 4x4 HD max tow
2012 Jayco X19H
dougrainer
Carrolton, Texas
Posted: 05/20/19 05:35am Link  |  Quote  |  Print  |  Notify Moderator
Remove the refer vent cover and just snake the wiring thru the holes in the mesh. OR, drill a hole in the side of the mesh cover(not the lid), snake the wires thru there and then seal with silicone. Just drill your hole towards the top to prevent water run off from the roof hitting the hole. Doug
grizzzman
salt lake city, Utah
Posted: 05/20/19 06:25am Link  |  Quote  |  Print  |  Notify Moderator
also, there are sharp edges sending wires that way. A piece of sprinkler pipe down to the bottom of the fridge will protect the wire.
2019 Ford F150 EcoBoost SuperCrew
2016 Rockwood Mini Lite 2504S. TM2030. Grape solar 40amp controller
640 Watts Solar. Costco CG2 208 AH and Lifepo4 2P4S 100 AH
400 Watt and 2000 Watt Inverter's hard wired.
Boondocking is my Deal
RoyB
King George, VA
Posted: 05/20/19 06:43am Link  |  Quote  |  Print  |  Notify Moderator
I have done a lot of cable paths under my floor on my off-road popup trailer using the PVC CONDUIT and ELECTRICAL Conduit boxes. When I need to come up under cabinets inside the POPUP I cut a hole in the bottom of the conduit box...
I actually did a round robin under my floor shown in blue below and have at least 4-5 places where it comes up inside the trailer. The beauty of this is all my cables are now inside PVC conduit and electrical boxes. After I am done then I can mount the conduit box lid and all is out of the way...
This is a typical PVC Conduit box with ports. They come in all sizes with all kinds of port configuration. When I need to get inside the trailer I cur a hole in the middle of the box. Then I can seal everything with sealant. No more pulling cables off under my trailer when running the back off road trailer with my POPUP...
Google image
Roy's image
I will probably go with the same more permanent installation for my up coming solar plans for the roof... I like to drill holes in the side of the roof to gain entrance to the inside of the trailer and not on the roof itself... I expect I will be using the ALUMINUM UNISTRUT going across the roof and attached to brackets on the side of the roof where I can drill holes...
Something like this...
google image
I can run another install between my roof mounted air condition and the end of the roof...
I add some PVC Electrical boxes on the side and go through the side to another PVC BOX ion the inside behind the wrap around valance curtains we have that goes around the whole inside of the trailer... Every thing will be in conduit and out of sight...
Hanging flapping wires on the side of the trailer would not be my thing to do...
Of course everyone has different situations..
Just some of my planning here for future solar panels... I am seriously thinking about removing my Air Conditioner and adding a second fantastic fan in the 14-inch hole through the roof. This will free up a lot of room on the roof for solar panels... Since we are off-grid most of the time the Air Conditioner doesn't get used much for us...
Roy Ken
f150camper
Oregon
Posted: 05/20/19 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everybody!
When drilling into the side of the mesh cover, do you use dicor to seal? Or really silicone?
ajriding
st clair
Posted: 05/20/19 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Considering all the possible options on mine I ended up just snipping the bug screen and ran wires through the top opening of refridge vent. Easiest and with no new holes comes no new leaks…
Route wires from the back side if you do this so rain water when driving will not run up the wire and into the compartment.
Also, this method is very un-doable if you remove the solar system.
Whatever you do make the most direct path to the batteries (controller too) that you can. DC power likes short wires of big gauge.
time2roll
Posted: 05/20/19 08:45am Link  |  Quote  |  Print  |  Notify Moderator
I drilled a hole in the side of the vent and used a 2 hole strain relief. These are waterproof.
https://solarconduit.com/shop/strain-rel........atertight-1-2-inch-2-holes-12-guage.html
For the wire down I used an MC4 extension cable cut in half. MC4 ends to the panels, cut ends on the controller.
675w Solar pictures back up
f150camper
Oregon
Posted: 05/20/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everybody again!
I am still going forth and back on how exactly to do the wiring.
Yeah, that's one of the issues. The fridge vent location is not ideal. I would likely need an ~ 18ft run from controller to the batteries. Ideal would be almost diagonally from the fridge vent, at the right front trailer corner, going straight down into the storage compartment below, install controller there, and then route like 4 or 5 feet (through the floor) to the batteries on the tongue.
But I do not like the idea of having to drill a hole through the rubber roof of my X19H. [emoticon]
time2roll
Posted: 05/20/19 09:57am Link  |  Quote  |  Print  |  Notify Moderator
You already have lots of holes in the roof. Just seal with Dicor.
If the fridge vent is not ideal I would go with the J-Box sealed to the roof.
Possibly use a GoPower cable entry. https://gpelectric.com/products/cable-entry-plate/
PNW_Steve
Pacific Northwet & cold
Posted: 05/20/19 10:18am Link  |  Quote  |  Print  |  Notify Moderator
I would suggest checking the temp rating on the wire and measure the temperature near the top of the vent while the burner is running.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
