RV.Net Open Roads Forum: Class C Motorhomes: Low mileage issue
 > Low mileage issue
VA-Apraisr
glen allen, VA
Posted: 05/22/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
I agree with those that don't consider low mileage a detriment, rather, a positive! I've bought many cars with super low miles (2000 Ford Mustang with 2000 miles and was 12 years old at the time; 2002 Oldsmobile with 9000 miles and was 14 years old; a 1990 Mustang with 1600 miles and was 15 years old; 1998 SL500 with 16k miles and was 16 years old, .....none ever had a leak or issue. I look for these vehicles). That said, it's the RV portion that can be neglected/damaged from non-use and maintenance. Don't let the low miles send you down the road, rather, investigate the RV carefully and you may find a true gem that has many, many years left in it.
Posted: 05/26/19 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Good advice and considerations. Bottom line, it's situational. Low miles is just one indicator of the remaining service life or impending costs.
You need to look at all factors that affect potential service life and future costs.
BTW, the old "hoses etc are rotten in 10 years" is largely false, but again it's situational.
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
VA-Apraisr
glen allen, VA
Posted: 05/27/19 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed, Grit dog, ....... never had any of those vehicles listed in my post spring a leak, blow a gasket, drip oil/trans fluid...nothing! My advise "DON'T BUY any of these low mileage vehicles; LEAVE THEM FOR ME! [emoticon]
Bordercollie
Garden Grove, CA, USA
Posted: 06/06/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Our 2004 Tioga 26Q was used once on a cross country trip and later on a trip up the coast from LA area to Oregon and otherwise has mostly sat in the driveway during our home remodel, surgeries and recoveries. I am having the generator serviced and house batteries replaced and already had roof vents and plastic cover for fridge replaced, all roof seals re-sealed. The fridge, roof A/C unit and awning were replaced 5 years ago. I'm having a pro mechanic check the engine, cooling system, transmission, and brake system, changing oil and filter and general tune up. Michelin tires with near zero miles look new but will have them checked and replaced any signs of unreliability. RV tires are "iffy" even when new in my opinion. You might use the above as a guide in what to look for in a used low mileage RV. Test everything for proper operation including lights, windows and shades and test drive thoroughly. Make a list and get estimates. Buying any used RV is like buying a house and then getting "surprises" during renovation. Good luck!
 > Low mileage issue
