RV.Net Open Roads Forum: Tow Vehicles: CP4.2 Bypass kit
Search only in Tow Vehicles
 > CP4.2 Bypass kit
Page of 6
ShinerBock
SATX
Posted: 05/20/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Lucky for me I don't have to get another truck for a while. Another good thing on my side is I am not afraid to void the useless warranty that I have never needed in any of my Cummins trucks by replacing the CP4.2 with an old CP3 if that time comes. Most mods I do increase reliability by removing things that are prone to fail and/or decrease engine longevity.
Posted: 05/20/19 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Seems like a great solution, but seems too simple?
Millions of these pumps are out there and the OE couldn't come up with a way to keep them from sending parts downstream?
AlmostAnOldGuy
Oregon
Posted: 05/21/19 05:58am Link  |  Quote  |  Print  |  Notify Moderator
For each pump sold the OEM saved $360. Multiply that by those millions and that is a lot of money to protect against an infrequent issue. But apparently Bosch also lost some business if GM switched to Denso.
Now if I owned the vehicle I would look at 360 as a bargain because any failure would be a big deal.
Take it easy,
Stu
2012 F150 HD/Max Payload (8200 GVWR, 2176 payload) SuperCrew EcoBoost
2008 Komfort Trailblazer T254S
Flashman
Tucson, Aizona, USA
Posted: 05/21/19 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Remember GM and VW honored their warranties - it was Ford that shafted the owners. Great fix especially if you own a Ford diesel.
ShinerBock
SATX
Posted: 05/21/19 07:35am Link  |  Quote  |  Print  |  Notify Moderator
BMW also honored their warranties and even extended them for all customers using the CP4.1(single piston) and CP4.2(dual piston) version, but didn't seem to have that many issues.
There haven't been issues with the Cummins 5.0L in the trucks or medium duty from what I seen. The VM Motori Ecodiesel hasn't seem to have issues either, however, these two engines might be using the updated CP4.2.
* This post was edited 05/21/19 07:49am by ShinerBock *
kirkl
Washington
Posted: 05/21/19 08:14am Link  |  Quote  |  Print  |  Notify Moderator
What year Rams have the CP4.2? I have a 2017 ram.
2017 Ram 2500 6.7 Cummins 4x4 LB
2018 Wildcat Maxx 28RKX
1999 Northland 8ft Camper
Honda 2000 Generator
wnjj
Cornelius, Oregon
Posted: 05/21/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Take it easy,
Stu
This aftermarket item is $360 but making such a minor change to the original design would likely do nothing to the cost of each piece. It would have been a one time engineering cost with significant benefit.
IdaD
Idaho
Posted: 05/21/19 08:24am Link  |  Quote  |  Print  |  Notify Moderator
2019+
You have a CP3.
2015 Cummins Ram 4wd CC/SB
ShinerBock
SATX
Posted: 05/21/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
The CP4.2 is on the "updated" 2019 6.7L.
They had to do it in order to increase power output and meet emissions. While the CP3 puts out enough volume of fuel than the stock engine(turbo restricted) is capable of, it does not put out enough pressure to do it and meet emissions at the same time.
Basically they reduced reliability in order to increase power and meet emissions so they can keep up the pissing match. I for one was fine with the old stock power levels if it meant keeping the CP3 and just increase power afterwards with a tuner, but some people just gotta want more and more for bragging rights even if it lowers reliability.
Cummins12V98
on the road
Posted: 05/21/19 09:25am Link  |  Quote  |  Print  |  Notify Moderator
FishOnOne wrote:
Cummins12V98 wrote:
Good info for the "F" guys!
Also good info for the RAM guys because it shows there was an inssue 14 and prior but from everything i have NOT heard the 15 and newer pumps are not having nearly as many issues.
The CP4.2 is still very sensitive to fuel contamination and aeration no matter how you spin it.
NOT spinning anything! RAM has had a high quality fuel filtration system since 2013.
Time will tell if the pump Cummins chose to use will hold up. Ya Gots 100k coverage to see how it goes.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Page of 6
 > CP4.2 Bypass kit
