RV.Net Open Roads Forum: Jayco X19H Roof does not support weight of solar cells?
 > Jayco X19H Roof does not support weight of solar cells?
Crestview area, Inyo County, California
Posted: 05/20/19 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
And the heat goes where, MDK? Just touch a solar panel in a SoCal summer and you’ll see.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
dougrainer
Carrolton, Texas
Posted: 05/20/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
What Jayco means is, the Roof on a Hybrid is designed with certain Stress supports. They install supports for the roof AC weight which is about 100 pounds. The roof will indeed hold 250 lbs of a person. I weigh 250 and have been on countless Jayco Hybrids doing roof and AC work. What Jayco is stating is standard CYA language. Even tho your unit is way past warranty, Jayco will not state what to do and will just discourage you from doing it. There is no problem installing Solar Panels on your Jayco. Doug
f150camper
Oregon
Posted: 05/20/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
That was my first thought also.
There was so much snow on that roof two years ago that a couple solar panels would add literally nothing compared to the snow load.
What I am not 100% sure about is the screws holding the panels down at highway speeds, but most likely that would be ok as well.
* This post was edited 05/20/19 07:16pm by f150camper *
Nights camped 2011: 13 (4 in the old popup) ">
Nights camped 2012: 36
Nights camped 2013: 28
Nights camped 2014: 21
2012 F-150 XLT screw 4x4 HD max tow
2012 Jayco X19H
opnspaces
San Diego Ca
Posted: 05/20/19 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
keeping the panel on the roof is not a weight issue but an attachment issue for wind getting underneath.
Change it up and open a new ticket and ask Jayco if there are wood trusses or what is under the roof deck allowing you to walk on it. See if they will send you a diagram for where the trusses are, or you can probably figure it out by the amount of flex underfoot while you're up there.
If wood trusses I would say it;s standard CYA and you can mount them.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
allen8106
Burrton. KS
Posted: 05/23/19 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
The roof support a heavy a$$ air conditioner, I assure you it will support the panels. It's a liability issue for Jayco.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 26
CincyGus
Cincinnati
Posted: 05/23/19 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds CYA to me. If you have 1/2" Plywood laminated to foam, the screws should hold. If you have Wood trusses in some sections, that would be the ideal mounting point obviously. You're not risking warranty and I'm confident you will be fine in either situation as far as roof structure. If you don't have trusses to screw into and will just be going into the 1/2" plywood, buy some extra mounts and put 8 on each panel to add some additional strength instead of just 4 if that makes you feel better.
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
