RV.Net Open Roads Forum: Tech Issues: Need AC help
 > Need AC help
rvnutts
Hampton, Arkansas
Posted: 05/21/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
My husband just replace our 2013 Dometic Ac with the new dometic Brisk Air II. Works fine, compressor kicks on and off but the fan runs co tinuously, never kicks off. Does anyone know what is probably the cause of this?
Brian and Lynn
2017 Ram 2500 SLT 6.7L
2013 Heartland Big Country 3250ts
rk911
Wheaton IL
Posted: 05/21/19 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
in our MH we have the Coleman Mach 8. our thermostat fir cooling has 5-options,,,
- low cool
- high cool
- auto cool
- low fan
- high fan
on low or high cool the fan runs continuously but the compressor will start/stop based on the temp set at the t-stat. on auto cool both the compressor and fan will start/stop together again based on the need for cooling. maybe your Dometic is the same??
'73,
rich, n9dko
Remember...if you don’t know where you’re going you're bound to end up somewhere else.
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
12th Man Fan
Flower Mound , Texas
Posted: 05/21/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
If you have the fan setting on anything other than Auto it will not shut off.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
DarkSkySeeker
Freestone, California
Posted: 05/21/19 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Same as mine.
There is something special about camping in an RV.
rvnutts
Hampton, Arkansas
Posted: 05/21/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, thanks. I will check and see if i can change the fan setting.
Gulfcoast
Southeast
Posted: 05/22/19 01:26am Link  |  Quote  |  Print  |  Notify Moderator
Mine has low fan, high fan, low cool and high cool but no auto fan.
* This post was edited 05/22/19 05:31am by Gulfcoast *
dougrainer
Carrolton, Texas
Posted: 05/22/19 05:29am Link  |  Quote  |  Print  |  Notify Moderator
Need to know if it has a wall tstat or ceiling mount controls. Changing the top AC unit ONLY, will not change the way the original controls operated the Unit. If Ceiling controls, there is NO way to put the fan on Auto. Wall mount controls will have an Auto setting to turn the Fan OFF. Doug
Wherever I happen to park
Posted: 05/22/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Some A/Cs are designed that way
Fact. If you cycle the fan on and off it is much much much more annoying than letting the fan run constantly.
Home is where I park it.
rvnutts
Hampton, Arkansas
Posted: 05/22/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Thanks so much for replies. I will have to wait for the weekend to check the auto setti g out. We had to put it back in our shop for bad weather. Hope to see Sunday if i can fix it.
Cocky_Camper
Rock Hill, SC
Posted: 05/22/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Probably the fan setting as mentioned. But we run our fan the majority of the time, because it is quiet annoying when it turns off and on during the night. I sleep better with the consistent noise.
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
 > Need AC help
