RV.Net Open Roads Forum: Tech Issues: Watts Help Needed.
 > Watts Help Needed.
Page of 6
jbfoster
California
Posted: 05/21/19 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
I am trying to figure out how long a battery will last. I have Googled it and read a few sites but I still have a few questions.
I have a small TV that I plugged into my Kill a Watt meter. That shows 22 watts. I plan on using a 1000w inverter hooked to one 12v battery. I havn't purchased a battery yet so i'm not sure how many AH I will have to work with.
At 12v that would be 1.8 amps.
at 124v that would be .18 amps.
Which amp usage would I use, the 1.8 amps or .18 amps?
Thank You
Jim
elivi8
Langley
Posted: 05/21/19 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
A standard 12V battery will have around 90 amps and you can only use about half of that so 45 amps else you will shorten the life of the battery.
You would be using the 1.8A number at 12V.
Ryan
2012 F-150 EcoBoost, Max Trailer Tow
2011 Cougar 26BHSWE
time2roll
Posted: 05/21/19 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
I would round up to 3 amps and call it 15 hours.
675w Solar pictures back up
jbfoster
California
Posted: 05/21/19 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
That will be plenty I think. Pretty much all I will be doing is the TV and maybe charging two cell phones. I'm also getting the Westinghouse iGen1200 generator. It's a 1000 watt and 1200 watt peak. I'm guessing the max amp battery charger would be 8 amps this generator could handle. I would probably get a 5 amp battery charger and then run the generator 2 to 3 hours or less a day to top of the battery. Almost forgot the 650 watt coffee maker to make a cup or two a day. That shouldn't be to much at 600 watts for about 3 minutes a cup.
Jim
pianotuna
Regina, SK, Canada
Posted: 05/21/19 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
Divide watts by 10 to get amps @ 12 volts.
Divide amp-hours of capacity by 2 to get usable amp-hours.
Regards, Don
MrWizard
Traveling
Posted: 05/21/19 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
don't confuse DC amps and AC amps
a 5 amp charge at 13v+ is only 65 watts
8 amps at 120v input too a battery charger or converter is 960 watts
you want a charger/converter between 30 and 45 amps DC charge
500 to 700 watts of charging
5 to 10 amps of charging will take days to recharge/replace what you use
Radiate The Happy
1997 F53 Bounder 36s
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 05/22/19 12:50am Link  |  Quote  |  Print  |  Notify Moderator
Inverters at low percentage of potential percentage of power are sooey-sooey pig-pig hogs of power. You are forgetting the 20% Charge Efficiency Factorial. 20% vigorish the battery charges for loans. Do all your VA calculations then add the 30% minimum replenishment energy premium.
I wish it was more efficient.
Wherever I happen to park
Posted: 05/22/19 06:40am Link  |  Quote  |  Print  |  Notify Moderator
YOu need to add an amp for the inverter overhead
But when you say 1 12 volt battery.... Well that can be anything from a couple amp hours to over a thousand. Just so you know
Minimum recommended for a 1,000 watt inverter is 200 amp hours.
Home is where I park it.
Airdaile
On The Road
Posted: 05/22/19 07:19am Link  |  Quote  |  Print  |  Notify Moderator
You want to look at a battery's reserve capacity rather than amp hours.
prichardson
Lafayette, La
Posted: 05/22/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Forget the coffee maker when on battery power only.
Page of 6
