RV.Net Open Roads Forum: Tech Issues: Watts Help Needed.
 > Watts Help Needed.
Page of 6
BFL13
Victoria, BC
Posted: 05/24/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
You might have missed this earlier. This one is quiet, runs on propane, same as your BBQ/camping stove, and will run a 25 amp charger. Perfect for your beach scenario!
https://www.rv.net/forum/index.cfm/fusea........d/29853063/gotomsg/29890403.cfm#29890403
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
pianotuna
Regina, SK, Canada
Posted: 05/24/19 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Jim,
I think DB levels are taken at a distance of 7 meters (22.9659 feet). I may be wrong about this.
A larger generator with an eco switch may be more fuel efficient than a smaller one. It may also be quieter.
When the time comes that you have an RV with a microwave the 1800 watt will power it--and the 1000 may not.
* This post was edited 05/24/19 10:38pm by pianotuna *
Regards, Don
MrWizard
Traveling
Posted: 05/24/19 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
your charge WON'T USE 25 amps, it might charge at 25 amps at 14v = 310 watts
25 amps 'use' times 120v would be 3000 watts
amps will 'ALWAYS' taper down
a charger doing 30amps at 14v will still taper to 1amp at 14v when the battery is near full
battery capacity & ability to accept the charge determines the amps at 'ANY' voltage
a partially used battery has a lower internal resistance than a charged battery
as the battery charges, the resistance to accept charge also increases
the battery controls the amount of charge it accepts, not the charger
automatic 'car' battery chargers, turn OFF, when the battery acceptance slows down
they shut off before the battery is fully charged
i know this is a lot to learn,
BUT learning to understand the 'terms' correctly, and correctly charging your battery, will save you money and future problems and expenses
Radiate The Happy
1997 F53 Bounder 36s
pianotuna
Regina, SK, Canada
Posted: 05/24/19 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
Nice post Mr Wizard.
310 watts / 0.7 power factor gives about 443 watts.
Page of 6
