RV.Net Open Roads Forum: Beginning RVing: One night running the heater and blower
 > One night running the heater and blower
Page of 5
SoonerWing03
Oklahoma
Posted: 05/22/19 09:27am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure what battery I have on the camper but I am sure it has the original battery (I'm at work or I would go look). It's a 2017 Cruiser RV - MPG 2400BH and has a 30,000 BTU heater. We have not been brave enough to try any dry camping yet but was thinking about it tomorrow night. We are going to be traveling to Colorado for a long weekend and I was hoping to take off Thursday afternoon and drive about half way and then finishing the trip Friday morning.
My question is this, I believe it will get down to around 50 degrees Thursday night and am wondering how long I will be able to run the furnace on that original battery. Will it make it through the night if I set the thermostat st 60 - 65 degrees and don't use any lights or any other power? We will have full hookups at our campsite in CO so it will be fully recharged the following day.
I have read about the catalytic heater option with low oxygen shut off but I just can't pull the trigger on that with my wife and 3 boys in the camper. I'm sure it would be fine but I just can't do it.
Near USFS Glass Creek CG, Inyo County, CA
Posted: 05/22/19 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Should be easy to determine the amp hour draw and then your battery’s AH capacity with 50% useable. What make and model heater? 60 to 65F overnight seems warm to me, however. Dry camping is great! True freedom.
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL flagpole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
midnightsadie
ohio
Posted: 05/22/19 10:08am Link  |  Quote  |  Print  |  Notify Moderator
well maybe. the battery full charged? water level full? post and cables clean? don,t turn it on till your ready for bed. it might do it.
time2roll
Posted: 05/22/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
50 is maybe not even cold enough to cycle on much. I think you will be fine with the temp set at 65 or lower.
Worst case you will have a bit of a chill in the morning.
675w Solar pictures back up
janstey58
Glenwood, IA
Posted: 05/22/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
At 50 degrees I would have the windows open and enjoy the cool air. Or just use extra blankets and take off the chill in the AM when you wake up. Just other options.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
smarty
new mexico
Posted: 05/22/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
We always take a second fully charged battery when we boondock. Just in case...
I think you will be fine for one nite tho...
way2roll
Wilmington NC
Posted: 05/22/19 10:48am Link  |  Quote  |  Print  |  Notify Moderator
LOTS of variables. How many batts do you have, how old are they, what condition are they in, how warm are you planning on setting the t stat, what's the R value of the rv, etc, etc.
All that said, one batt, in good shape with a full charge should get you through the night at 50 degrees provided you don't set it to 80.
One note, open a bath roof vent or something. A by product of LP burning is water vapor and will drive up the humidity in your RV.
way2roll
Wilmington NC
Delete - victim of "service unavailable"
* This post was edited 05/22/19 01:40pm by way2roll *
Matt_Colie
Southeast Michigan
Posted: 05/22/19 10:51am Link  |  Quote  |  Print  |  Notify Moderator
I cannot find it in the specifications, but if it is a single battery, then it is a bad bet. With any single battery and a 30K heater by anybody, it will want about 10 amps when the fan is running. That will kill any normal battery before morning.
So, if you run that heater more than about 6 hours from a fully charged battery, it may go down.
If you come back tomorrow with more about your house bank and what the heater is, I can give you a more accurate answer. You may not like it any better, but it will be closer.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
Matt_Colie
Southeast Michigan
delete "Service unavailable again
Page of 5
