RV.Net Open Roads Forum: Tech Issues: RVs and the NEC
 > RVs and the NEC
road-runner
Oregon
Posted: 05/24/19 11:42am Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
You can make all the nonsense claims you want. The fact is, YOU have no idea how RV's are really built. There IS a Final inspection and the plumbing is tested and LP is tested.
To be clear, I'm not contradicting this statement. Of the 80 build defects I found when my motorhome was new, none of them involved the plumbing or propane system. Several of the defects were in the DC electrical system and had a very real risk of starting a fire. If the DC system was inspected it was a fraud.
2009 Fleetwood Icon
dougrainer
Carrolton, Texas
Posted: 05/24/19 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
You are confusing a Final inspection with a in depth inspection. You assume an in depth inspection. What they do is a system check of operations. The pressure test both the LP and Water system. Finding 80 defects means YOUR dealer did a lousy PDI. Granted, there should not be 80 defects, but a good dealer would have found most of those before you did. Doug
dougrainer
Carrolton, Texas
Posted: 05/24/19 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
BillyBob Jim wrote:
dougrainer wrote:
BillyBob Jim wrote:
JaxDad wrote:
Make no mistake though, that seal by the door certifying the unit as conforming to NFPA 1192 or whichever standard it's built to is most certainly a legal requirement.
NFPA compliance is a voluntary requirement companies claim they meet. Having the RVIA seal is not mandatory. All that seal says is the manufacturer is a member of the RV Industry Association and claims they comply with NFPA, ANSI, whatever. Nothing says you have to be a member of RVIA to build and sell RVs. The RV Industry Association lobbies hard for minimum requirements. Why do you think most states have no lemon laws for towables. Bingo....the RVIA. A dead giveaway is RVbusiness.com which is sponsored by RVIA. They sugar coat and carefully select every article they have ever published, and are very good at turning a turd of an industry into a Rose.
There are no code inspectors on or at the end of the line in RV factories certifying anything meets anything else. If one feels good and safe because they have an RVIA seal that's what its designed to do, mission accomplished. Reality is slightly different when brakes quit working, the plumbing and LPG system has multiple leaks, and the wiring connections are never tightened..
You can make all the nonsense claims you want. The fact is, YOU have no idea how RV's are really built. There IS a Final inspection and the plumbing is tested and LP is tested. The RVIA seal is not required, But, each seal must be paid for to the RVIA. The RVIA does inspect RVIA members to make sure the minimum standards are met. Do, things get missed? YES. But, EACH dealer is supposed to do a full PDI on every new unit sold and that includes Plumbing checks and LP Manometer test. IF dealers fail to do that, that puts them at liability if there is a LP leak they missed. There is no requirement that Dealers do these PDI's and tests, but a dealer is foolish to not do them. Sometimes that is the difference between that great low price and what other dealers are selling for. As to the "Yoder" brothers, 40 years ago that would be a true statement. In Michiana today the majority of RV line workers are NOT Mennonite or Amish. Doug
Ooooops forgot you are the all knowing swami where RVs are concerned.....I stand corrected. I assume all those gents with the bowl haircuts, beards, and homemade shirts and gals with the dresses and bonnets at the 5 or 6 factories I have been through around Goshen and Elkhart were Democrats. And your 100% correct, lots of things get missed. LOTS.
You just joined. FYI. I worked in Goshen/Middlebury and lived there from 1970 til 1979. I CLEANED the production plants after school and then worked building Motorhomes and Trailers. Then I moved and became a RV technician starting in 1979. Now, that puts ME as an obvious expert. You may not like the idea that there is someone like me on these forums, but I am here and some newcomer can make all the derogatory comments he wants. People that have followed my posts know I am usually spot on and when I make a mistake I own up to it. I make regular training visits back to Michiana at least every few years and also go thru the plants. The Plant people have evolved to regular people and Mennonite and Amish make up very few of the total plant people. Doug
PS, you can read my post but in general keep your mouth shut when it comes to responding about me.
BillyBob Jim
US
Posted: 05/24/19 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
No.....I'll reserve the right to respond about whatever pleases me posted by whomever no matter when I joined. FYI I have been involved with plenty of folks with 40 years under their belt in trades or professions whom were only experts in their own minds.
Have a great holiday.
D.E.Bishop
Eagle Rock, CA
Posted: 07/01/19 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
In response to BB_TX, you may be correct but...
NFPA INCLUDES
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
time2roll
Posted: 07/01/19 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
D.E.Bishop wrote:
In fact there are three states that have not adopted the NEC.
What do they follow?
675w Solar pictures back up
3 tons
CA.
Posted: 07/01/19 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve been busy converting my dual voltage power saw (120 or 240v) to run on 240v by using the ground in the power cord as a neutral...Works great though I can’t recommend it....
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 07/02/19 02:26am Link  |  Quote  |  Print  |  Notify Moderator
the info
the camaraderie
the rutting
 > RVs and the NEC
