RV.Net Open Roads Forum: Capping off a propane line: need tips and tricks!
 > Capping off a propane line: need tips and tricks!
profdant139
Posted: 05/22/19 11:52am Link  |  Quote  |  Print  |  Notify Moderator
After great effort, I just now found my very slow propane leak (and I will soon prepare a fascinating [emoticon] report on the many things I learned while trying to find it). Bottom line – the leak is at the point that the external barbecue fixture connects to the propane system.
What I want to do is remove the barbecue fixture – we never use it. And I want to cap off the stub or nipple that "tees into" the propane line. The pipe is galvanized. It appears to have an ordinary pipe thread -- not a flared brass gas fitting.
I am planning to unscrew the existing reducing bushing (I think that is what it is called) and replace it with a galvanized cap. I will use teflon gas tape at that joint.
My real question is this: I don't want to put any stress on the other galvanized propane lines underneath the trailer. I will hold back on the galvanized nipple with a pipe wrench while unscrewing the existing reducing bushing. The bushing is very rusty -- I anticipate having to use a lot of force to unscrew it. I'm planning to spray it with WD-40 a day or so before unscrewing it, to try to loosen the threads.
Does this sound like the right approach? I am not a plumbing or propane expert, as you can tell.
Thanks in advance for your suggestions!!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
wrktfsh
Here n there
Posted: 05/22/19 11:57am Link  |  Quote  |  Print  |  Notify Moderator
That’s how I would do it. Use pipe dope on the threads. Turn off gas first
Chris Bryant
Arden, North Carolina
Posted: 05/22/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Should be black iron, not galvanized, but other than that, it’ll be fine.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Old-Biscuit
Verde Valley
Posted: 05/22/19 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
YEP....
Always use 2 wrenches
1 to HOLD existing pipe and 1 to use to remove other pipe/nipple etc
Pipe dope the threads (yellow tape will work....several wraps)
MrWizard
Traveling
Posted: 05/22/19 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
i prefer 'Kroil' or 'PB blaster' much better penetration, bushing will come out easier
I would use a Brass cap, and Yellow Teflon tape is for Gasses, white Teflon is for liquids
Radiate The Happy
1997 F53 Bounder 36s
Bobbo
Wherever I park
Posted: 05/22/19 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Contrary to popular belief, WD40 is not a penetrating lubricant! Get some PB Blaster. Best stuff on the face of the planet for what you are doing.
On a related note, personally, I prefer pipe dope to PTFE tape.
Bobbo, Linda and the furry kid (45 pound rescue)
MrWizard
Traveling
Posted: 05/22/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
i agree with the pipe dope on a capped line
tape can sometimes be a PITA to use
profdant139
Posted: 05/22/19 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
Some great tips -- thanks! I hope to avoid becoming a "pipe dope."
LarryJM
NoVa
Posted: 05/23/19 01:48am Link  |  Quote  |  Print  |  Notify Moderator
I agree "PB Blaster" (My preference) is XXX times better than WD40. Best to let the PB Blaster work for a day or two reapplying as necessary to keep fitting wet. It takes time for the PB Blaster to really be effective so it's not a quick one step process.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
Wherever I happen to park
Posted: 05/23/19 06:01am Link  |  Quote  |  Print  |  Notify Moderator
There is a different dope for gas threads (I think it is yellow in color) and they generally use "Black Iron" pipe.. any hardware. ANY hardware department. Just take the old fitting in so you have the right size.
Home is where I park it.
