RV.Net Open Roads Forum: Tech Issues: Clear As Glass Ice Cubes?
 > Clear As Glass Ice Cubes?
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 05/22/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Boil the water first? I must have done something wrong [emoticon]
DR650
TX
Posted: 05/22/19 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Use distilled water......
2008 F350 V10, Auto, Crew Cab, XLT, Long Bed
2005 Rockwood 2104
2017 Yamaha XT250 Dual Sport Motorcycle
wildtoad
Blythewood, SC
Posted: 05/22/19 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure of the point but boiling the water first will help assure it is safer to drink.
Tom Wilds
Blythewood, SC
fj12ryder
Platte City, MO
Posted: 05/22/19 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
I read once that boiling water before freezing will aid with clear ice cubes. Have no idea if it works, but I read it somewhere once.
Howard and Peggy
"Don't Panic"
LittleBill
Scranton, PA USA
Posted: 05/22/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
hi folks, clear as glass ice cubes are made by freezing water that is in constant movement, air is what causes the cloudiness, not the water content
DFord
Near St Louis, MO
Posted: 05/22/19 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
Flowing water does make a great clear ice cube as well as the other tips offered here. The reason boiled water and distilled water make a clearer ice cube is because they lack the air that's entrained with most tap water. It's the air in the water and any other impurities that freeze after the pure water around the sides freeze. In the old days of ice making plants, there was a device known as a "core sucker" that sucked out the center of the ice block as the outer shell was freezing and replaced it with fresh water to make a clearer block of ice. Pure water freezes first and then the impure water with air and minerals freezes last and that part of the block/cube is cloudy. Nothing in it that will hurt you but it looks better.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
MrWizard
Traveling
Posted: 05/22/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
i use water from 'water machines' to make ice in my portable ice maker
its all clear when i take it from the machine and but it in the freezer
but some will harden clear and some will harden cloudy
probably more cloudy ice than clear ice
Radiate The Happy
1997 F53 Bounder 36s
agesilaus
North Florida
Posted: 05/22/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
That's correct the dissolved gases make it cloudy. If you have a tank of helium you 'sparge' the water with helium, bubble the helium thru the water using one of those aquarium bubbler stones and that will remove the gas from the water. Distilled water might help.
I've also heard that freezing the water in thin layers works but could get very tedious. I assume that allows the gas to escape as the water freezes.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
GordonThree
Northern Michigan
Posted: 05/22/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
As I understand it, if you freeze the water in one direction, if gives the gasses room to escape.
See here for one way to do this, he used regular tap water.
https://youtu.be/n5H2Opjql9g
Sorry I'm on my phone, can't make it a click.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
rockhillmanor
On the Road
Posted: 05/22/19 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Boiling water only kills the bacteria. it won't eliminate the particulates in water. That is what clouds ice cubes, the more cloudy the cubes are the more junk is in your tap water! [emoticon]
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
