RV.Net Open Roads Forum: Tech Issues: using propane for fridge
 > using propane for fridge
kbottcher
pa
Posted: 05/22/19 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
I use propane side of fridge to get it cold before we camp.I know i need battery to turn fridge on.Can i use battery disconnect to turn battery off then, or will the fridge then not run?
thanks in advance
Kerry
2oldman
New Mexico
Posted: 05/22/19 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Dunno. Try it. If the interior light doesn't come on, no. Why does your profile show a website that's just a IP address?
wildtoad
Blythewood, SC
Posted: 05/22/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Even if you run the fridge on propane you need 12v power to the fridge. No power, no Fridge.
Tom Wilds
Blythewood, SC
pianotuna
Regina, SK, Canada
Posted: 05/22/19 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
My fridge turns off if I cycle the battery disconnect switch to the off position.
Regards, Don
1492
Arlington, VA
Posted: 05/23/19 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
profdant139
Posted: 05/23/19 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
The control panel for the fridge runs on electricity. It doesn't draw much power, but it does need a little!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
DrewE
Vermont
Posted: 05/24/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
It depends on the fridge to be absolutely precise. Some (old) models did not have any electrical control circuitry for operation on gas, and so did not need battery power; you just opened a gas valve and lit the flame and maybe adjusted its size to control how much cooling you got.
Most if not all current models have electronic controls that need 12V power regardless of whether the fridge is operating in gas mode, 120V mode, or 12V mode if it's a three-way fridge. Almost certainly your fridge is in this category and does require some 12V power to operate.
2oldman
New Mexico
Posted: 05/24/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
He's gone.
Ron3rd
Upland, CA USA
Posted: 05/24/19 09:04am Link  |  Quote  |  Print  |  Notify Moderator
X2. Rule of thumb: if you lose 12v power, the only thing that will work is your stove.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
wolfe10
Posted: 05/24/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
To clarify:
Yes, your refrigerator must have 12 VDC to operate on either 120 VAC or propane. It powers the PC board.
The real question comes in as to how your coach is wired. Some wire 12 VDC to the refrigerator through the salesman switch, some provide an alternate direct routing so that you can turn off the salesman switch to kill lights, etc and have the refrigerator remain running.
Simple to determine. Turn off the salesman switch and see if the refrigerator still works.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
