RV.Net Open Roads Forum: General RVing Issues: Water pump
 > Water pump
LOFAT36
Canada
Posted: 05/22/19 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
After 6 months in Arizona, arrived home end of March in Canada. Drained and winterized after getting home. Today I filled the fresh water tank and turned on the pump to fill the hot water tank. Now the pump won’t shut off. I left it off for a hour so but when I turn it back on it still runs. No leaks anywhere. Any ideas ?
rockhillmanor
On the Road
Posted: 05/22/19 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
It means something is open somewhere. Would help to know what type of RV as water inlets differ.
Check your water inlet fill cap on tight and check the screen inside. Check valves can get worn out or just pushed out of position. Push it with your finger to reseat and try again.
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
LOFAT36
Canada
Posted: 05/22/19 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
. 2011 Rockwood TT. Fill cap is on and I never touched any valves when I got home. Is there a reset on the pump ?
pianotuna
Regina, SK, Canada
Posted: 05/22/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
when you open a tap does water come out?
Regards, Don
LOFAT36
Canada
Posted: 05/22/19 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.
LOFAT36
Canada
Posted: 05/22/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. I put the hot water tank on gas and when it reached temp and shut down I released the check valve for relief in the tank. Same thing, turned on the pump and it keeps running.
Dutch_12078
Winters south, summers north
Posted: 05/22/19 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
There may have been some water left in the pump that froze and changed the pressure switch adjustment. Check your pump manual for the correct adjusting procedure.
Dutch
2001 GBM Landau 34' Class A
12th Man Fan
Flower Mound , Texas
Posted: 05/22/19 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
How long has it been running? First thing it does is fill the water heater if it is not bypassed.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
pianotuna
Regina, SK, Canada
Posted: 05/22/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Sounds like a torn membrane in the pump.
MrWizard
Traveling
Posted: 05/22/19 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
CITY WATER FILL 'pump' bypass valve ??
our safari had that, had to be open to fill the water, and closed to use the pump
* This post was edited 05/22/19 08:18pm by MrWizard *
Radiate The Happy
1997 F53 Bounder 36s
 > Water pump
