RV.Net Open Roads Forum: If you had a do-over, which would you get?
 > If you had a do-over, which would you get?
Damdifino
Comfort, TX
Posted: 05/22/19 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Honestly, if you could do it again would you go for a Mercedes diesel or a Ford V10?
2013 Casita 17' Freedom Deluxe
2014 Arctic Fox 22H.
2009 Toyota Land Cruiser URJ200 Series
Desert Captain
Tucson
Posted: 05/22/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
No question I would stay with my V-10 Ford, just have had too good of an experience over the last 6 years and 50K+ miles to make a change. I tow a light cargo trailer, motorcycle and trailer only weigh 2,220# but especially if towing anything heavier the V-10 is the way to go. Not towing and have lots of money then the smaller Mercedes may be your cup of tea but...
Unless you drive hundreds of thousands of miles the fuel consumption differential will never equal the additional initial cost for a Mercedes diesel not to mention the increased cost of maintenance. No Mercedes C can even come close to matching the room and storage I have in our 24 footer.
As always... opinions and YMMV.
[emoticon]
klutchdust
Orange, California
Posted: 05/22/19 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Ford V-10.
I have wrenched as a career and have worked on just about anything with a steering wheel.
I know this, the V-10 is a gas guzzling powerhouse that is a reliable engine. I know two individuals that have have exceeded 350K on theirs with minor repairs.
Any mechanic can work on the V-10. Keep spare ignition coils with you, I'm told.
Mercedes. Owned a diesel car and anything associated with Mercedes is double the price. Not everyone knows or understands their engines. Not every shop has the diagnostics to find the problem. Mine was a 300D without computerization, easy for me to repair however in a motorhome I would not have it. Mercedes makes a good engine but expensive to repair.
IF you were to need repairs miles from home you could be towed to most shops and get help, Mercedes, not too much.
navegator
San Diego CA.
Posted: 05/22/19 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hands down the V-10 from Ford, had the fuel pump replaced in Santa Fe at the Ford dealer hard to do at a campground, I worked for Mercedes long time ago, beautiful engines, a pain in the neck to work on, I redid all the sparkplug threads with Timecerts not helicoils on the V-10 at home over a weekend, do all the mainenance on it, other than the fuel pump it has more power than what we need to go places and tow the toad.
It is a 24 foot bumper to bumper "actual measure" no slide, bed is a queen and there is plenty of room, no need to make way for tables chairs just eat or having to make the bed every night, and there is plenty of clearance to off road with out scrapping enything down there.
navegator
MDKMDK
Canada
Posted: 05/22/19 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
Another Ford versus Mercedes thread?
OK, here goes, once again. I hate these threads, but I find them strangely compelling. And, I was bored.
The fuel economy difference explained using simple math....
Start with $1000.
Regular unleaded costs $2.79 in Michigan today. Lowest price at Marathon per Gas Buddy.
$1000 will get you ($1000/$2.79 = 358 gallons) of fuel.
At an overall average of 8 MPG with a Ford V10 (based on the manually calculated average consumption of my 2016 Sunstar 26HE 3ValveV10, 6 speed transmission, but not towing - they don't put a fuel economy gauge in the Ford V10 on the F53 chassis, at least not mine), I would be able to drive 358 gallons X 8MPG = 2867 miles.
Start with the same $1000
Diesel costs $2.95 in Michigan today. Exxon lowest price per Gas Buddy.
$1000 will get you ($1000/$2.95 = 338 gallons) of fuel.
At an overall average of 15.5MPG with my MB 3.0L V6 turbo diesel (based on using the fuel economy gauge for a period of several weeks while traveling, but not towing), I would be able to drive 338 gallons X 15.5MPG = 5254 miles.
That's quite a bit more driving on the same amount of money. Almost 45% farther with the MB diesel. I'll take that. Simple math. It adds up quickly at the gas station and at the bank.
To add fuel to the fire (pun?), I live in Canada where it's even better for the diesel engines today. Diesel is C$1.19/L and regular unleaded is C$1.35/L. I rarely pay that, though. I get most of my fuel in Michigan. I should also mention the Sunstar was about 2500lbs heavier than the Navion. About 13,000lbs versus about 10,500lbs.
Everyone says that it's more expensive to maintain the MB. Probably. Parts are more expensive, but they seem to last longer. Oil changes cost more, but are done less frequently. Fewer places can work on them, but not every Ford dealer or corner garage can accommodate a big RV either, I know because I got my first and last oil change on the Sunstar (only 27' long) at a truck stop in Maine, because not one Ford shop near me could handle it's size. Forget about suspension, alignment, and other chassis work on them, they won't fit on or are too heavy for most dealership hoists. I know because I asked. You buy a big class C or a small Class A motorhome with the Ford chassis and engine and you could have some trouble finding service, and will probably have to use big truck shops to get a lot of the routine stuff done. Size matters to a Ford, too. I would bet most Ford V10 owners can't do their own maintenance, so they're going to have to deal with some of those same issues as us MB owners.
Neither motorhome/chassis/engine is perfect, they both have pros and cons, big and small, but I think I prefer the MB Sprinter chassis, overall. It's quieter, has incredible performance for a small engine, no doghouse, and it just drives well. I only have to go 60 miles for chassis service, and they can actually do it there, no farming anything out to heavy truck shops. My Navion fits in their shop and they can do everything I'll ever need done to it. I consider myself lucky in that respect. Out on the road, that's a different story, but it all depends on what fails, and where you are when it does, whether it's a Ford V10 or an MB V6. The MB chassis could fail 5 miles or 105 miles from a capable dealership or a qualified repair facility, but so could a Ford V10 chassis. Out there, it's largely luck of the draw, for everyone.
I like my Mercedes based motorhome. I would buy another one, all things considered.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
pnichols
The Other California
Posted: 05/22/19 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
The same here on everything mentioned so far in favor of a Class C motorhome based on a Ford V10 powered E-Series cutaway van.
In my opinion, the Mercedes chassis and it's engine is too complex (and hence expensive to repair and service) for general RV use here in the U.S. - especially when used in the more rural areas for camping trips. However that might not be the case in Europe, because I think that they're more "diesel vehicle centric" across the pond.
We take our small V10 powered Class C off-highway, and it's ground clearance, reliability, and general ruggedness provide a lot of confidence for us. Another detail not mentioned much is that even at the V10's average miles per gallon consumption rate, probably Class C motorhomes based on it with the stock 55 gallon fuel tank have a greater touring range than what the Mercedes 2500 and 3500 cutaway van chassis provide.
Phil, 2005 E450 Itasca Spirit 24V
ernie1
Sacramento,California,USA
Posted: 05/22/19 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
Just sold my Ford v10 based rv last year and bought a Mercedes based class c. Never in 89,000 miles did I ever do a thing to the engine other than oil and filter changes. Mostly I could do about any mechanical repair to this thing short of a transmission rebuild. I'm shocked that people call this engine a gas guzzler. I was getting anywhere from 12-14 mpg. My Mercedes 3500 class c averages about 14-15mpg. To be fair, the mercedes rv is about 3feet longer but still! Hands down, the Ford v10 is the best and this is the first and last Sprinter.
Tripalot
Golden Horseshoe, Ont. Canada
Posted: 05/23/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Have used a Ford V10 for 10+ years - Sprinter is not on our "want" list.
2014 Triple E Regency GT24MB (Murphy Bed) with all the good stuff
towing a 2016 Jeep Cherokee TrailHawk
Berkley, the amazing camping cat missed dearly (1996-2012)
ol' yeller
Redmond, WA
Posted: 05/23/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
I've owned 3 V10s. A 1999, 2008, and now a 2019. It is an incredible engine for the motorhome application. I know nothing about Mercedes except for their expensive reputation. Why change that which works?
I am NOT a mechanic although I do play one in my garage!
klutchdust
Orange, California
Posted: 05/23/19 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Not clear on your message. Are you saying you get 12-14 with a V-10 or the diesel. If with a V-10 which class c. My 30ft. rarely exceeds 9. I travel at 55 or 65 and no difference, all within a tenth.....
