RV.Net Open Roads Forum: are RV microwave ovens the same as kitchen ones?
 > are RV microwave ovens the same as kitchen ones?
anon125
anywhere
Posted: 05/22/19 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
our 2006 winnebago itasca had brackets top and bottom of the microwave oven to hold it into a 20 inch by 15 hole.
do non Rv ones have the holes to screw the brackets to the microwave?
thanks all
2006 Itasca sunova 29r
BFL13
Victoria, BC
Posted: 05/22/19 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
MWs are the same, but you have to drill your own holes as required to use the surround.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
winnietrey
seattle
Posted: 05/22/19 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
No they are not. MH microwaves vent to the top, household to the back. That may become an issue if you do have not clearance in the back, for it to vent, if you put a household one in
winnietrey
seattle
double post delete
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 05/22/19 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
You might want to select a unit that has a mechanical door latch that will stay shut and not allow the platter and carousal merry-go-round roller to fall to the floor while driving.
WILDEBILL308
FORT WORTH , TEXAS
Posted: 05/22/19 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
thanks all
I have found no difference.We have changed 2 in different coaches and the only thing different is you have to adjust the vent to blow in the right direction. The instructions are in the box. Bought both from Home Depot and were shipped free.One was a direct replacement the outher was a upgrade to a convection/microwave.You can find the dimensions of the old one and find one that will fit in the same hole.
All the holes are already there, you don't need to drill new ones.
Bill
2003 BOUNDER 38N
5.9 CUMMINS 300 HP
ALLISON 3000MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
BFL13
Victoria, BC
Posted: 05/22/19 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Use a car jack on the stove, shimmed up by telephone books, to hold the MW up to the cabinet bottom while you screw in the holding bolts.
CarnationSailor
Carnation,WA
Posted: 05/22/19 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Not true in all cases. My RV MW vents to the back and my home MW vents to the top.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
garym114
Bluff Dale, Texas
Posted: 05/22/19 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Most microwaves can be installed and vented several different ways,rear vent, top vent or no vent at all.
There is no real difference in the microwave itself.
Joe417
AL
Posted: 05/22/19 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
A difference I've noticed is that many RV microwaves don't have a clock feature. Kind of makes sense. Keeps you from having to reset the time when you power back up.
Our home microwave will not operate until we set the time after power is restored.
Joe & Evelyn
