RV.Net Open Roads Forum: Tech Issues: Costco battery?
 > Costco battery?
Page of 6
swimmer_spe
Sudbury, Ontario, Canada
Posted: 05/22/19 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
My TT needs a new battery. I am not normally boon docking it, yet, so I only need a battery for the typical load of it sitting unplugged from shore power. So, which Costco battery should I get?
Do not suggest other places as I am in Canada, and don't have Autozones, Pepboys, etc...
Do not suggest the 2 6 volt set up as that is not my need.
stickdog
Somewhere, USA
Posted: 05/23/19 12:28am Link  |  Quote  |  Print  |  Notify Moderator
What series battery do you presently have, if it has served you well the same should work in the future.
9-11 WE WILL NEVER FORGET!
17 MS 36 RSSB3
Gone 04 HH DA LS 33.5 RLTG
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
swimmer_spe
Posted: 05/23/19 12:42am Link  |  Quote  |  Print  |  Notify Moderator
I don't know. It is a marine starting battery from somewhere else.
azrving
Oatman
Posted: 05/23/19 01:10am Link  |  Quote  |  Print  |  Notify Moderator
A group 27. Marine/RV
Group 27
swimmer_spe
Posted: 05/23/19 01:25am Link  |  Quote  |  Print  |  Notify Moderator
Group 27
Sam's clubs do not exist here.
As I stated before C-O-S-T-C-O
bikendan
Camano Island, Wash.
Posted: 05/23/19 02:49am Link  |  Quote  |  Print  |  Notify Moderator
you also need a battery to power the trailer breakaway switch, while towing the TT.
if you never dry camp or boondock, a Group 24 dual purpose marine battery is fine. US Costcos carry Interstates, not sure about Canada.
Dan- Firefighter">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 Ecoboost, 2016 PrimeTime TracerAIR 255 w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
garyemunson
Reno, Nevada
Posted: 05/23/19 05:25am Link  |  Quote  |  Print  |  Notify Moderator
You may not need the golf cart batteries...but... If you have room (many TTs are putting the batteries in a compartment now), 2 6 volt golf cart batteries from Costco wired in series will be about the same price as one marine deep cycle. They will provide more power and last longer. The one time you are out and every campground is full and you are forced to WalMart it, you will be glad you went that route. If you are stuck with the single battery box on the tounge, stick with the marine.
* This post was edited 05/23/19 07:25am by garyemunson *
MudChucker
Niverville Manitoba
Posted: 05/23/19 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Costco varies from province to province... Virtually any marine/deep cycle group 27 - 31 battery at Costco will be fine. Measure your battery box dimensions and bring tape measure to Costco and buy your best bang for your buck battery. Keeping in mind dimensions,or.change battery box.
You have battery stores like. Batterybattery.ca out there you might consider calling them and ask what they have in deep cycle lead acid 12 volt, there are some really decent RV deep cycle batteries that can be had for.under $300.
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
Wherever I happen to park
Posted: 05/23/19 05:54am Link  |  Quote  |  Print  |  Notify Moderator
Nothihg wrong with Costco batteries.. Last I checked they were made by a good quality battery maker (However they may have changed suppliers in the last decade) but if you are only using for "Road power" (Basically the safety brake battery) Most anything will do.. Costco, Canada Tire. Wal-Mart.. Whatever stops your trailer.
Home is where I park it.
CA Traveler
The Western States
Posted: 05/23/19 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Simple answer: Take your old battery to COSCO for an exact change.
2014 Grand Cherokee Overland
Bob
Page of 6
 > Costco battery?
