RV.Net Open Roads Forum: Class A Motorhomes: Best diesel pusher chassis ?
 > Best diesel pusher chassis ?
navigator2346
texas
Posted: 05/23/19 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
DynoMax
Executive
Posted: 05/24/19 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Most people respond to a question like this with "The BEST is the one I own". I always buy the best. Like's been said, Ford or Chevy. Each mfg has it good points and their less than good points. Chevy is built like a rock, but it's an ugly rock. Ford looks cool but can't hit a basket to save it's soul. Narrow your selection then look for the good and bad on the chassis that coach is built upon. Chassis are but one piece of the puzzle anyway. For instance, Monaco built all their older coaches on their Roadmaster chassis. Their best was/is the RR10R with 10 air bags mounted on the outside the frame rails. Very solid very good ride etc. But, only the luxury coaches, Signature, Executive, Dynasty and later the Camelot, have steel cages. IMO, all the chassis mfg are excellent. It's what's assembled on top of them that makes all the difference when you're driving....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Big Katuna
Deland, FL
Posted: 05/24/19 10:37am Link  |  Quote  |  Print  |  Notify Moderator
They mostly use common components eg rear ends, trans, Cummins pick a size.
With or without IFS, Haladex air controls, compressor, etc.
I don’t know if I’d get married to these modern pollution systems.
Lightly used quality unit pre problematic pollution system.
My Kharma ran over my Dogma.
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 05/24/19 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Last motorhome was on a Spartan. Current motorhome is on a Freightliner.
I really can't tell any difference in the way they feel going down the road. Steering is precise with both and passing trucks have very little effect on handling.
Chassis won't be a concern when looking at another motorhome. Engine HP, that's a different story.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
tropical36
Southwest Florida_USA
Posted: 05/24/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Between Spartan and Freightliner, there was a time when the Spartan was optional on some coaches and never knew one to not have a side radiator, whereas most all the FL's had a rear radiator and were mainly found on entry and mid entry level coaches.
Nowadays, it seems that FL has the better chassis available as well, so most sure, there's not much of a difference.
Foretravel has partnered with Spartan in recent years, if that might tell you anything.... Foretravel and Spartan
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
zxer
Eugene
Posted: 05/24/19 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
navigator2346 wrote:
DynoMax
Anything special about the Dyno as opposed to the others ?
mike brez
Unknown
Posted: 05/25/19 06:07am Link  |  Quote  |  Print  |  Notify Moderator
X2 On what Dennis said.
My is Gillig and it's the best. lmao
I have also owned the worse a P30
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Airdaile
On The Road
Posted: 05/25/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Magnum chassis by SMC were on several late 90s early 2k Safaris, Beavers and some Harneys. CAT 3126, Allison 3000 series, exhaust brake. Built specifically for motor homes. The biggest issue was the rear radiator/CAC getting plugged up with road grime and oil. Just stay away from the torsilastic suspension.
paddock_rat
Do Not Understand
Posted: 06/01/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Ivylog wrote:
10 airbags...Prevost, Newell, Foretravel, Monaco Roadmaster which includes 2004+ Beaver, HR, Safari all on the RR10S for the handling and 9,000+ of CCC. The newest Monaco is NOT on a RR10S chassis.
At this time, there are only four three axle pusher chassis available in the motorhome market, Freightliner (owned by Daimler Benz), Spartan, Prevost, and Newell.
10 air bags? No currently available chassis uses 10. Nor I suggest is this relevant to the "best chassis" discussion.
ZF (Germany) manufactures the most advanced coach suspension systems in the world, and are used world-wide by top-tier coach builders. ZF suspensions are available to the motorhome manufacturers (optionally) with computer-controlled suspension, and active or passive tag axle steering. (Only one chassi/motorhome manufacturer includes either ZF computer controlled suspension and active tag axle steering--guess who).
But back to the number of air bags. ZF independent front suspension has two air bags, their highest capacity drive axle suspension has four air bags (mounted outboard ahead of and behind the drive axle), and their tag axle has two air bags. That is 8 air bags total.
For those wanting 10 air bags, where would the other two go?
Ivylog
Blairsville, GA and WPB, FL.
Posted: 06/02/19 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
“Only 8 airbags, not 10”. You inaccurately assume the OP is looking at newer DPs. He is not as he included Roadmaster and Dynomax in his question. Yes, “currently” the big three are no longer on 10 airbags after years of using 10...the difference is ZF does not use a solid front axle. I know were I’d try and put the 2 extra ones.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
