RV.Net Open Roads Forum: Tech Issues: TST 507 parts are expensive.
 > TST 507 parts are expensive.
DavinD
Litchfield Park, AZ
Posted: 06/04/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tip on the HD o rings. I've broken new ones from TST just trying to stretch them on. I never understood why they made them so tight.
2018 Coachman Chaparral 381RD
TV - 2013 Ford F350 Diesel SRW 4x4 Short Bed
RCMAN46
NorthWest
Posted: 06/04/19 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
" I had a sensor fail. It reported no change in the tire pressure even after the tire had totally ripped itself apart. I no longer trusted the system I had. TST was no help, even though the sensor was less than a year old. I did end up buying a hew TST system as it seems to have the best reputation on the forums"
JoeH
Apollo Beach,FL
Posted: 06/05/19 05:32am Link  |  Quote  |  Print  |  Notify Moderator
K_and_I wrote:
JoeH wrote:
I've had outstanding customer service from TST. I called when I needed a couple screws for the anti-theft caps and they sent me a package of screws, extra caps, o rings for the valve stem connection and o rings for the battery cap--- all free of charge. I have enough to last a long time
I need to figure out what I'm doing wrong. I called TST a couple of years ago for o-rings, and was quoted a price and an equal price for shipping. I ended up ordering 2 sets of o-rings since the shipping charge was the same. Last trip (last month), I had a sensor fail. It reported no change in the tire pressure even after the tire had totally ripped itself apart. I no longer trusted the system I had. TST was no help, even though the sensor was less than a year old. I did end up buying a hew TST system as it seems to have the best reputation on the forums, and I wanted the color monitor and repeater. I got it from Great RV Products rather than TST directly.
How do some of you get this stuff sent free?
I suggest you call Mike Benson at 210-420-0132-- He's the sales manager at TST and has been very helpful.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
K_and_I
North Central Ohio
Posted: 06/05/19 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I watch the TP monitor fairly closely. I didn't see any pressure drop. We got to our location for the evening, and saw that one tire was completely shredded. I went back to the truck to check the monitor, and it still showed the tire had normal pressure (with no tire there at all).
K_and_I
2011 Rockwood 2604
Nights Camped in 2019: 85
Do we have time for shortcuts?
RCMAN46
NorthWest
Posted: 06/05/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
My question is why after such poor support would you buy a second system.
If your truck had a engine failure when under warranty and they did not fix the engine would you then go buy a new truck of the same manufacture if it had the best reputation on a forum such as this one?
K_and_I
North Central Ohio
Posted: 06/05/19 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Possibly. Every company has a defective part or two sneak through. I usually buy items like this based on word of mouth as much as any other factor. If most are having good success with this product, chances are I will too next time around.
Whiskey River
Pittsburgh, Pa
Posted: 06/16/19 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Big shout out to "Delphi".
Just bought the Danco #30 model #96744 "O" rings and they are a perfect fit for the TST 507.
The last time I changed batteries was just before leaving on a trip & no time to call TST so I used a small dab of goop glue. Just finished digging out all the goop & the Danco 30 fit perfect.
$2.49 at Lowes for a 10 pack, can't beat it.
Thanks Delphi.....
