RV.Net Open Roads Forum: Fifth-Wheels: Fold up stairs blocking door
 > Fold up stairs blocking door
richheck
Modesto, CA
Posted: 05/28/19 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Torklift Glowstep Revolution has just released a model that will replace yours allowing you the option of using them in such a confined area. Just got word of these.
Link to new steps
* This post was last edited 05/28/19 10:07am by richheck *   View edit history
2013 Ford F-350 4WD DWD 6.7PSD
2010 Jeep Wrangler
2017 Landmark 365 Arlington
Lynnmor
Red Lion
Posted: 05/28/19 10:35am Link  |  Quote  |  Print  |  Notify Moderator
laknox wrote:
Are those steps optional? If not, then any rig that has them is right off my list.
Lyle
Go to a large RV show and you will see that many, if not most, have these simple to install steps. While there, watch the folks stumble over the step supports that jut out into the aisle. People don't think and can be sold anything.
Allworth
Orlando, FL
Posted: 05/28/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Pins with locking clips (like the ones that hold a hitch to the rails) might work.
You might want to add some kind of gussets to the bolt hole areas to stiffen the mounting.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
ReneeG
Meridian, Idaho
Posted: 05/28/19 11:48am Link  |  Quote  |  Print  |  Notify Moderator
FLY 4 FUN wrote:
your exact situation is the one large downside to these steps. I do LOVE the rigidity of them, but when in storage I rarely have the room to deploy/use this great upgrade. I hope that industry comes up with a work around for those of us that end up in narrow spaces occasionally.
Agree. Not to mention that we often stop over at rest areas for the night and those type of steps would stick too far out in the road to safely leave deployed.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
AZ T&T
Mesa, AZ
Posted: 05/29/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
RCMAN46 wrote:
Sell your current steps and replace with these.
RV Steps
Couldn't agree more! I love my TorkLift GlowStep Revolution steps. You can actually use them almost straight up and down.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
buc1980
houston tx
Posted: 05/30/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
I like my Glow steps too.Very easy to set up and fold.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
Lantley
Ellicott City, Maryland
Posted: 05/30/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Link to new steps
The above linked steps do appear to be your best solution
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
GaryUT
Northern UT
Posted: 05/31/19 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
Morryde makes removable solid steps.
2 Brackets bolt under the door and the stairs clip into them.
Quick connect step
Gary
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
mxdad777
Ca
Posted: 05/31/19 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. I ordered the Torklift steps today. After all the good things you had to say, I figured they must be good and they definitely will fix my problem.
Thanks again for the input.
2018 Rockwood Signature 8299BS 5th wheel
2019 GMC Duramax 4x4
Bob Vaughn
Seffner, Fl.
Posted: 06/01/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
I absolutely love my Torklift Revolution Glow steps.....I just added the Glow ride stair rail and that thing is phonominal......
