RV.Net Open Roads Forum: Travel Trailers: LED LIGHTS
 > LED LIGHTS
kennyd63
Minooka, Illinois
Posted: 05/27/19 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
My wife can't stand the led lights on our new T.T. she would like to change them to a more warm looking type. I told her that's going to cost us an arm and a leg if we are going to change every light inside of the camper specially if it's led. Now she brings lamps into the camper for that reason, just to make it look more warm looking. I really don't know what to do[emoticon]
Please help!
Thank you all in advance.
2019 Braxton Creek 24RLS
2010 Forest River Salem 403FB-Destination Trailer
2014 F150 4X4 Crew Cab
rbpru
North Central Indiana
Posted: 05/27/19 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
There are "warm" and "cold" LEDs. They go by various descriptions. Check out Amazon and EBay. They are not all that expensive.
They also comes in various sizes and levels of brightness.
I went from incandescent to LEDs so wire gauge was not an issue.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
pianotuna
Regina, SK, Canada
Posted: 05/27/19 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
Change the ones she uses. They truly are not that expensive. The first one I bought was $67 and could be replaced today for $1
Regards, Don
folivier
Southeast Louisiana
Posted: 05/28/19 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Definitely check eBay. One suggestion is to buy from a USA supplier and not overseas. Makes it much easier if there is a problem and shipping is much quicker and the price difference won't be noticeable. $1/bulb is a good estimate. In my last motorhome I had over 70 halogen bulbs to replace!
Buy a couple cheap ones from different suppliers to try out before you order all of them.
LoudRam
Southern NJ
Yep, ours are harsh to. I installed led rope lighting above the crown molding across the slide and it gives nice up lighting. Before that my wife put a lamp on the table. We use them for night time lighting unless we need the brighter light.
Todd
Desert Storm Vet (US Navy)
2014 Ram 1500 Quad Cab 4X4
2018 Dutchmen Aspen Trail 2880RKS
If you can read this thank a teacher
If you can read this in english thank a vet
Sandia Man
Rio Rancho, NM
Posted: 05/28/19 09:51am Link  |  Quote  |  Print  |  Notify Moderator
LEDs come in a variety of radiances, when we did a full interior conversion to LEDs we chose a warm luminance that mimicked the incandescent bulbs we replaced quite well. We purchased from an Ebay store recommended on this forum, very economical and every LED panel array still works as good as when I installed them 5 years ago. Buy a few to find just the right hue your DW prefers before going all out.
AppFire
N.C.
Posted: 05/28/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
2 dozen warm light led bulbs from amazon was $16 shipped via prime. Had them the next day. Worked great!!
2017 Silverado Crew cab LT Max tow package
2003 Jayco Qwest 244
ktmrfs
Portland, Oregon
Posted: 05/28/19 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
most often what is installed is similar to a cool white, 4500 K or so.
Warm white, near an incandesent bulb is 3200K, normal incandesent is 2800K
so look for color temperature.
One warning on cheap replacements. LED's want to be driven by a constant current. the good ones have a circuit that holds the current constant. the cheap ones have a dropping resistor. Converter comes on, voltage goes to 14ish volts, current goes up, LED junction voltage drops 2.2mv/C as the LED heats up, increasing current more, pretty soon you end up with a dead LED or one that gets hot enough to unsolder itself. (seen that happen)
Or battery voltage drops, LED's get pretty dim quickly. At least that doesn't do any damage.
Downside of the ones that regulate current is if not done properly the can give interference to TV/radio etc.
A few years ago good ones were spendy, but today good ones with regulator are reasonably priced and much more common than a few years ago.
2011 Keystone Outback 295RE
Shadow Catcher
NW Ohio
Posted: 05/28/19 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
You are looking for the color temperature of 3200K the same as a regular incandescent bulb.
mosseater
Dillsburg, PA
Posted: 05/29/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
I put 3200k throughout the trailer and it's a great light. I spent about $8 per lamp times 13. The best part is, the led doesn't scorch the inside of the plastic lenses. Almost no heat at all. Well worth the upgrade.
Sunset Creek 298 BH
 > LED LIGHTS
