RV.Net Open Roads Forum: Dinghy Towing: Using EZ Pass while towing
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > Using EZ Pass while towing
ThomBoles
Pinellas Park, FL
Posted: 06/05/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
If you go to FL (or have a SunPass) don't think you're ever going to see the refund for getting tagged by both passes. I was towing the car with a sunpass and went over the skyway bridge 2x.
Called them a few times before giving up (*it was only a dollar anyway)
"we have to check the video" just means "Don't pass go, you're not getting your money back"
You can go on the SunPass site and inactivate a tag and re-activate when needed.
Not sure if the same holds true for EZPass. We have an Ohio EZPass on the RV only and just move it to the car if needed.
Thom and Diane Boles
2010 Winnebago Vista 32K
cross21114
Baltimore, MD, USA
Posted: 06/05/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
BillyBob Jim wrote:
cross21114 wrote:
In many cases, the combined toll is more than each individually. So if you disconnected and pass thru the toll booth and then hook back up, you can save money in some states.
Sounds like a real PITA to save a nickel IMO?
It is but imagine the savings if you unhooked and drove separately through the entering toll booth on a turnpike, hooked back up to travel the entire state, unhook before going through the ending tool booth? Could be significant. Probably not legal if caught.
Chris
2018 Nexus Ghost 36DS
360 Cummins, 3000 Allison
2016 Ford Expedition
