RV.Net Open Roads Forum: Tech Issues: Do I need a surge protector?
 > Do I need a surge protector?
steved28
Bellingham,MA,USA
Posted: 05/28/19 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
I know this sounds like a stupid question, so let me explain. My new rig has a Precision Circuits PCS, which works in hand with a Magnum 2Kw inverter. The documentation states that the PCS will work together via an inverter assist mode. The PCS also brings up circuits one at a time, has L-1 and L-2 voltage status, shows amperage draw, can detect between 30A, 50A and genny. And has alarms for brownouts, overvoltages, and wiring status error.
The auto transfer switch (Ironically made by Surge Guard) does not have any surge protection. So it seems the switch itself is not protected.
So before I invest around $300 in a Progressive Dynamics HW50C, I am asking if I actually need it? It seems some of the functions of it are redundant to ones I already have.
2019 Winnebago Sunstar LX 35F
2000 Jeep Wrangler TJ Sahara
ken1961
Posted: 05/28/19 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
My 2013 Itasca Ellipse has the factory protector but I still use a surge protector. The price is small compared to the damage that can occur.
Ken
Wherever I happen to park
Posted: 05/28/19 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
First there are surge protectors and surge PROCTERS the Hw-50C is the latter.
I've read of transfer switches and other devices with built in "Surge protection" but what I see when I look at them is spike supression. A Spike is a brief high voltage.. They do nothing for you if the voltage at the oullet is too low and if you plug into a 240 volt 30 amp outlet (Don't laugh and do not say it can't be done.. Happens all the time. often because somebody mis-wired a TT-30 or failed to read the "Max 125 volts" printed clearly upon it)
Well the MOV's in those things go off like July-4. Firecrackers.
Now the HW-50C will shut you down if the voltage goes low
It will shut you down if the voltage goes high
And it will protect you from Spikes.. Without firecracker effect
So yes. you need one.
I would put it in the line on the shore side of the ATS.. I don't worry so much about my generator. (Onan's monitor their output and shut down if it goes crazy)
Home is where I park it.
time2roll
Posted: 05/28/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
Alarms? If it still allows power through the RV You need the protector.
Who will hear the alarm while you are out walking?
675w Solar pictures back up
Mojave, Kern County, California
What’s the performance guarantee on the Precision Circuits PCS?
steved28
Bellingham,MA,USA
Posted: 05/28/19 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
I know. It's not really clear if it shuts down as part of it. I did see a brownout warning on the display once, but I did not know if it took action.
steved28
Bellingham,MA,USA
Posted: 05/28/19 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Perfect, thank you. I am off to Amazon land!
Ava
Vancouver Island. BC Canada
Posted: 05/28/19 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Mine also shows any errors if there is a polarity problem or missing ground from the pedestal which have both happened to me.
Shadow Catcher
NW Ohio
Posted: 05/28/19 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Our Progressive Industries EMS has saved us a couple of times.
Shadow Catcher
NW Ohio
A miss wired pedestal and open neutral.
