RV.Net Open Roads Forum: Tech Issues: Do I need a surge protector?
 > Do I need a surge protector?
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 05/29/19 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
The NOM rating for power down here is not
110V
117V
120V
It is 127V
But Mexican campgrounds use 14 gauge wire so it doesn't take much imagination to see why there is variance between high demand and middle of the night electrical periods. I've seen a 35 volt variance between 5PM and 4AM
cavie
Posted: 06/01/19 03:35am Link  |  Quote  |  Print  |  Notify Moderator
down home wrote:
Found out after we bought one that our coach has surge protection built in but... I still prefer that the 300.00 or less unit we plug into the tower, post, outlet or whatever to take the hit instead or at least first. It saved us grief a few times. In Missouri the campground had both 50 amp circuits going to one leg. The unit kept everything from frying on that leg and half the coach was dark.
I'm not sure that was the diagonsis. It has been a long time. In Michigan a campground we visit a lot on a packed holiday weekend a surge then brown out was caught by the unit. Another occasion lightning hit power distribution, something or other and popped the unit. During a storm some trees and high tension lines, came down and all kinds of fireworks popped the unit.
Our unit is undamaged but I have read here and elsewhere, over the years, of RVs being saved by the units which themselves were sometimes fried. In some reports the mfg replaced the damaged units but not always. I don't remember the two or three brands or even what mine is at the moment. It plugs into the pedestal and cord into it.
There are post here on this forum and others of some RVers losing microwaves, air conditioners,tvs and every thing else from a surge,...and brown outs from low voltage. We don't have one of the EMS that boost voltage but it's on the list.. We see low voltage we turn on the generator and disconnect for time being.
EMS does not boost voltage. There are 3 different devices. Surge protector, EMS, and Auto transformer. Each one does a different job. Do some research.
Dtank
Posted: 06/07/19 12:03am Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
First there are surge protectors and surge PROCTERS the Hw-50C is the latter.
I've read of transfer switches and other devices with built in "Surge protection" but what I see when I look at them is spike supression. A Spike is a brief high voltage.. They do nothing for you if the voltage at the oullet is too low and if you plug into a 240 volt 30 amp outlet (Don't laugh and do not say it can't be done.. Happens all the time. often because somebody mis-wired a TT-30 or failed to read the "Max 125 volts" printed clearly upon it)
Well the MOV's in those things go off like July-4. Firecrackers.
Now the HW-50C will shut you down if the voltage goes low
It will shut you down if the voltage goes high
And it will protect you from Spikes.. Without firecracker effect
So yes. you need one.
I would put it in the line on the shore side of the ATS.. I don't worry so much about my generator. (Onan's monitor their output and shut down if it goes crazy)
[emoticon]...[emoticon]...YES !!
[emoticon]
