RV.Net Open Roads Forum: freezer solutions for new rv'er/elk hunter. Arctic Fox 990
 > freezer solutions for new rv'er/elk hunter. Arctic Fox 990
gkainz
Arvada, CO, USA
Posted: 05/29/19 11:06am Link  |  Quote  |  Print  |  Notify Moderator
new2this44 wrote:
Thank you all very much for your ideas! I'm looking in to all of the suggestions. A lot to think about!
To clarify, I'll be full-timing in the camper. There will be no dedicated hunting site. I'll hunt again when I run out of meat/there is room in the freezer.
That changes the equation from what I'm used to seeing. I would still look at a small chest freezer, generator or primarily solar and more batteries on a small utility trailer, before I would swap out the fridge for a freezer.
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
valhalla360
No paticular place.
Posted: 05/29/19 11:49am Link  |  Quote  |  Print  |  Notify Moderator
In that case, I would be looking at the Engle units someone else mentioned.
You need efficiency if you won't be plugged in all the time. These unit are designed for that.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
gbopp
The Keystone State
Posted: 05/29/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
That's the nice thing about beer. You can drink it cold or warm.
No refrigeration needed. [emoticon]
HadEnough
Traveling. Always.
Posted: 05/29/19 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
I know this idea is pretty far out there, and it would require a lot of labor,. But you could also can it. That would be a good way to go if you don’t want to get a freezer, don’t want to change the arctic fox,
wanderingbob
monticeeo, fla
Posted: 05/29/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
We carried a " dorm " size freezer in our trailer for a while , ran it off an inverter and a pair of golf cart batts. We could go 3 and 4 days without recharging .
Posted: 05/29/19 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
Powering it full time presuming you'll be in the back country quite a bit (I would if I was FT in a TC!) will be a challenge. I'm not familiar with propane freezers though.
Was gonna suggest little chest freezer on a hitch rack but that ain't practical full time.
Not a lot of room in a TC to put a freezer even if you run a generator daily to keep it frozen. Only thing I can think is if you don't use the oven you might fit one in place of the stove and just use a campstove or portable cook top on top of it. And a 120v pizza oven for when you gotta have a frozen pizza or biscuits or ......
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
zcookiemonstar
Midwest
Posted: 06/06/19 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
there are a lot of reviews on youtube for 12volt ref/freezers. That is what some of the nomads living in there vans cars or campers use. Many run them on solar power.
exaple
https://www.youtube.com/watch?v=29GD6bvzUJ0
